Discussione: Spektrum DX18
Vecchio 01 marzo 13, 10:11   #11 (permalink)  Top
chrigui
L'avatar di chrigui
Data registr.: 21-07-2006
Residenza: Ferrara - Molinella
dal manuale
"Antenna fades – represent the loss of a bit of information on that specific antenna. Typically it’s normal to have as many as 50 – 100 antenna fades on any one of the antennas during a flight. If any single antenna experiences over 500 fades in a single flight, the antenna should be repositioned in the aircraft to optimize the RF link.
Frame Loss – represents simultaneous antenna fades on all attached receivers. If the RF link is performing optimally, frame losses per flight should be less than 20.
Hold – a hold occurs when 45 contiguous (one right after the other) frame losses occur. This takes about one second. If a hold occurs during flight, it’s important to re-evaluate the system, moving the antennas to different locations and/or checking to be sure the transmitter and receivers are working correctly. "
chrigui non è collegato   Rispondi citando
