Vecchio 06 gennaio 13, 23:19   #2 (permalink)  Top
victor66
L'avatar di victor66
Data registr.: 27-12-2008
Originalmente inviato da masmaron Visualizza messaggio
Futaba T12FG, Robbe FX30 issue ALERT
Apparently the problem is not new but the occurence seems to be much higher the past months. It doesn't affect all transmitters, but only some series.
On several french forums, a serious warning has been sent by T12FG/FX30 owners after several crashes conducting to the total destruction of the model. The issue is on the connection between the sticks potentiometer and the PCB. It comes from poor connector quality and the tension created of the wire a bit too rigid or short. Futaba/Robbe perfectly knows about this issue and know how to fix it. It is fix by changing the wires and soldering directly instead of using connectors. In france the issue fixed for free by the Futaba/Robbe repair center. The symptom is the following: on a empty new memory, neutral positions shift in the servo monitor menu, and alos in some mixers.
Anyway, it is abnormal that Futaba/Robbe doesn't proceed to an official recall, considering the seriousness of the problem and the high risk to have an accident with injured people.
Please forward to T12FG/FX30 owners you have around you.
secondo voi è il solito problema di connessione del potenziometro?
già riscontrato?
Ciao, uso una T12 FGH da 2 anni e mezzo e per fortuna nessun problema, certo è che sarebbe bello sapere i numeri di serie della partita "difettosa" in quanto potrebbe tornare utile a molti credo. Ciao.
ALIGN T-REX 500 ESP FUTABA T12 FG H http://modellismoticino.forumfree.it/
victor66 non è collegato   Rispondi citando
