Vecchio 22 ottobre 12, 22:39   #1 (permalink)  Top
fogarty01
Guest
Messaggi: n/a
Question ESC Hobbywing Platinum-40A-PRO
Salve,
ho comprato questo ESC per il mio Esky Belt-CP V2. Qualcuno di voi lo usa e sa quali settaggi consigliarmi?
Io in particolare non riesco a capire bene come:
1. settare il valore per il Timing del motore tra le opzioni
Timing:0°/ 3.75° / 7.5° / 11.25° / *15° / 18.75° / 22.5° / 26.25°, default is 15°.
2. settare il Governor Mode
Governor Mode:*Off / Governor Low / Governor High, default is “Off”.
If the governor mode is activated, the ESC will try its best to hold the motor speed at a fixed value. (Usually the throttle curve is a horizontal line, you can change the preset motor speed by changing the height of this line).
The speed range of “Governor Low” mode is 10000RPM to 45000RPM for 2 poles brushless motor, “Governor High” mode is 46000RPM to 200000RPM for 2 poles brushless motor. In order to calculate the speed of the main rotor blades of your helicopter, you need to know the motor poles number and the gear rate of main drive gear vs. the pinion. For example, if you are using a 6 poles
motor (that is: 3 pair poles), and the main drive gear is 150T, the pinion is 13T, so you can calculate as follows:
The rotation speed for the main rotor blades = (The speed of 2 poles motor * 13) / 3 / 150
3. PWM Frequency: *12KHz / 8KHz, default is “12KHz”.
DATI MOTORE:
3800KV, 6 poli, Lipo 3 celle
pignone 10T, main gear 140T
Cerco su internet ma non riesco a trovare spiegazioni e risposte alla portata di un principiante come me
grazie per l'aiuto!!
  Rispondi citando
