Vecchio 05 settembre 12, 16:19   #6969 (permalink)  Top
Robby Naish
L'avatar di Robby Naish
Data registr.: 16-10-2002
Originalmente inviato da romoloman Visualizza messaggio
allora sposta la antenna originale sul modulo e metti quella della frsky al posto dell'originale sopra la radio.
Io mi faccio un piccolo adattatore partendo da un tubo di alluminio per evitare l'uso della colla a caldo e per poter montare ogni tipo di antenna, tipo la patch,
non sai come la adoro in pendio quell'antenna...
Ecco, forse qui go trovatoqlc cosa
9x forums • View topic - Make Turnigy module removable with existing hard ware
anche se qs commento mi lascia perplesso
I'd like to remind everyone that every connector in the path subtracts from the 60 MW output. It's not like 72 or other frequencies where we started with 3/4 to 1 watt of output power. There is a point where the output power is reduced a lot. It all look great in our minds but in practice it's not always the best way to go. With the Frsky setup it’s easy to see what your range is because of the built in power reduction option. Has it been proven the FlySky module can have its power reduced to verify there is no range issue?
In close it all works. Sorry to bring this up but RF is a very serious technology that a EBay connector and a drill may not have all the answers for. The FlySky module was designed to maybe not have the impedance loss of an added connector (3db)? If you value your plane tread lightly on all the antenna mods.
Comunque l'antenna originale, si svita dall'interno, vero?
grazie
Ale
Robby Naish non è collegato   Rispondi citando
