Discussione: Categoria E-36
Vecchio 16 agosto 12, 11:19   #9 (permalink)  Top
giambattista
L'avatar di giambattista
Data registr.: 04-10-2006
se a qualcuno interessa queste sono le regole NATIONAL FREE FLIGHT SOCIETY 2011/122 estratte da:
http://freeflight.org/competition/NF...02011-2012.pdf
15.1 Model Requirements
1. 36 in. maximum projected wingspan allowed.
2. 120 gm. minimum weight, ready-to-fly, required.
3. No autosurfaces allowed .
15.2 Power Requirements
1. Any type electric motor allowed.
2. Nickel or lithium batteries allowed, 2-cell lithium limit or 6-cell nickel limit.
3. Gearing and folding props allowed.
15.3 Flight Requirements
1. Two minute maxes required for all flights
2. First three official flights to be made with a 15 sec. motor run each. If all maxes, a fourth flight to
be made with 10 sec. motor run, and if maxed, then all later flights to be made with 5 sec. motor
runs until a max is dropped.
3. Six attempts for the first three official flights is allowed, immediate declaration required and 20
sec. maximum for attempts, overruns being automatic attempts for the first three official flights
and overruns after the third official flight to be automatically awarded a "0" score
Be advised: the motor runs and two-minute maxes prescribed are seen as appropriate for large field
competition. CD’s are encouraged to modify the motor runs and maxes to suit local conditions. This is a
NFFS event and records won’t be kept, so fly smart and keep your models on the field.
tradotte pedestremente da Google:
15.1 Modello Requisiti
1. 36 pollici massima apertura alare proiettata consentito.
2. 120 gm. peso minimo, ready-to-fly, richiesto.
3. Nessun autosurfaces permesso.
15.2 Requisiti di alimentazione
1. Qualsiasi tipo di motore elettrico consentito.
2. Batterie al nichel o al litio ammessi, 2 celle limite di litio o 6 celle limite di nichel.
3. Gearing e piegatura puntelli consentiti.
15.3 Requisiti di volo
1. Due minuti arriva al massimo necessari per tutti i voli
2. Primi tre voli ufficiali da effettuare con un 15 sec. eseguire ogni motore. Se tutti arriva al massimo, un volo quarto
essere realizzati con 10 sec. funzionamento del motore, e se raggiunto il limite massimo, quindi tutti i voli successivi da effettuare con 5 sec. motore
ossia fino al un massimo di caduta.
3. Sei tentativi per i primi tre voli ufficiali è consentito, la dichiarazione immediata, necessaria e 20
sec. massimo di tentativi, il superamento di essere tentativi automatici per i primi tre voli ufficiali
e il superamento dopo il terzo volo ufficiale per essere automaticamente assegnato un punteggio "0"
Vi avverto: le piste a motore e di due minuti arriva al massimo prescritti sono visti come appropriato per il campo di grandi dimensioni
concorrenza. CD sono incoraggiati a modificare le piste del motore e arriva al massimo in base alle condizioni locali. Questo è un
Evento NFFS e le registrazioni non saranno mantenute, così volare intelligente e mantenere i vostri modelli sul campo.
Giamba
p.s: mi viene voglia di provare ....
Il sito del Pegna P7: http://giadel.webnode.it/
Promemoria : la gravità non perde mai!.... ma i miei modelli non lo sanno ...
giambattista non è collegato   Rispondi citando
