Vecchio 15 giugno 12, 07:21   #1 (permalink)  Top
axel83aerei
L'avatar di axel83aerei
Data registr.: 17-12-2010
Residenza: torino
Habu 32 Wemotec Midi Fan 80mm Carbon
CIAO a tutti nuovo esperimento per il mio Habu 32, girando avevo trovato la Jetfan 80mm che va' molto bene ma non mi soddisfava moltissimo, ma questa e' uno spettacolo, pesa pochissimo ho tolto altri 150g buoni dal mio habu per un totale di 2950g con una spinta di 2850g ottimo ventola efficentissima e consuma pure poco inoltre kit ventola e motore ad un super prezzo ecco le caratteristiche:
For 6s Lipo, 89 A, 28.5 N of thrust
This unit is a tuning drive for the HABU 32 or similar models and highest performance on 6s lipo. Since current can reach up to 100 A readily installed, we recommend 5.000 mAh cells 30 C or better and a good 120 A speed controller. Throttle management is recommended to reach a good flying time.
Midi Fan pro 80 is a shortened Version of our well known Midi Fan pro, trimmed down to 80 mm and fitted with a light carbon fibre shroud.
The shroudis compatible with the shroud of the 80 mm Eflite fan, which is being used in HABU 32 and similar models.
The fan unit comes completely mounted with a Tenshock EZ 22-30-9T motor.
The unit is assembled and checked at factory, precision balanced and harmonically tuned.
Set comprises:
1 x Midi 80 pro ducted fan unit
1 x Tenshock EZ 22-30-9
inner diameter: 80,0 mm
outer diameter: 83,6 mm
length of shroud: 66 mm
weight, complete: 292 grams
fan swept area: 37,68 qcm
rotor: 6-blades, Nylon (glass reinforced)
power input approx. 2.000 W
thrust: 28,5 N (approx. 2.85 kg)
rec. battery: 6s lipo, from 5.000 mAh 30C or better
rec. thrust tube dia.: 62 mm dieameter
Timing ESC: approx. 12°
PWM: 8-12 kHz
ecco il link. Midi Fan 80 ducted fan unit / Tenshock EZ 22-30-9T, 169,90 €
La potenza e' nulla senza il controllo
axel83aerei non è collegato   Rispondi citando
