31 marzo 12, 22:49
#2 (permalink)
Top |
| User
Data registr.: 18-01-2011
Originalmente inviato da pikemax Frsky strange\incredible range!!
guys!!!
i did the range check again...
switched the tx and the recever on, i pressed the module button for 5 seconds, the module led became green, i start walking and the servo began glitching at 190 meters, stopped moving at 200 meters...
i have the frsky v8 module without telemetry and the v8r7 recever, the module is powerd at 11,4 v and the recever at 5\6 volts, don't know the ppm voltage but its seems good  , stock 2db antenna
if it's usefull i did the mod in this way: [GUIDE] frsky diy on flysky ct6b (hk t6a) - RC Groups
Is this range normal? according to the manual 200 X 30 = 6 Km!!
Strange because the manual says that in range check it gives me only 30 meters..
what do you think guys?? Frsky strange\incredible range!! - RC Groups
Google? |
? Non l'ho capita
