Ci sono dei nuovi Turnigy sulla Warehouse tedesca
The Turnigy Trailblazer is a high powered 1/8 4WD monster truck thats ready to crush the competition! With its powerful 14.8V 80A brushless system pre-installed, this truck has plenty of power to take on just about anything.
Large oil filled shocks, aluminum alloy drive shafts, 3mm 6061 T6 aluminum chassis, and sealed ball bearings all the way around shows that this truck means business!
It comes fully pre-assembled and ready to run with a 2.4gHz radio system pre-installed. Just add your own 14.8V (2 x 7.4V in series) batteries to get this truck running.
Features:
- 4 Wheel Drive System
- Almost Ready to Run (just install your own radio system)
- High Performance 2230 540KV Brushless Motor
- 80A EZRUN Brushless ESC
- 3mm 6061 T6 Aluminum Chassis
- Waterproof and Dustproof Sealed Gearbox
- Quality Differential with Four Bevel Gears
- Sealed Ball Bearings for Entire Model
- Aluminum Alloy Drive Shafts
- High Torque Metal Gear Servo Pre-installed
- 2.4gHz 2CH Radio System Pre-installed
Specs:
Length: 504mm
Width: 385mm
Height: 188mm
Wheelbase: 335mm
Tire Size: 145x70mm
Ground Clearance: 46mm
Servo: 9KG Metal Gear (9KG)
Motor: 2230 540KV Brushless Inrunner (FB3650)
ESC: EZRUN-80A (EZRUN)
Radio: Turnigy 2.4gHz 2CH Pre-installed (FS-GT2)
Required:
14.8V (2 x 7.4V in series) 3000~3300mAh Lipo
The Turnigy Trailblazer XB is a high powered 1/5 4WD racing buggy thats ready to dominate the track! With its powerful 14.8V 80A brushless system pre-installed, this buggy has plenty of power to take home the win.
Large oil filled shocks, aluminum alloy drive shafts, 3mm 6061 T6 aluminum chassis, front/rear anti-sway bars, 3 differential transmission system, and sealed ball bearings all the way around shows that this buggy means business!
It comes fully pre-assembled, and includes a 2.4gHz radio system pre-installed. Just add your own 14.8V batteries (2 x 7.4V) and this buggy is ready to race!
Features:
- 3 Diff Transmission
- Alloy Steering Knuckles
- Almost Ready to Run (just add your own 2CH radio system and batteries)
- High Performance 1500KV Brushless Motor
- Sealed Precision Ball Bearings for Entire Model
- 2.4gHz Radio System Pre-installed
Specs:
Length: 688mm
Width: 430mm
Height: 250mm
Wheelbase: 480mm
Tire Size: 150x70mm
Motor: 1500KV Brushless Inrunner
ESC: EZRUN-80A
Radio: Turnigy 2.4gHz pre-installed (FS-GT2)
Battery Tray Size: 140Lx47.5Wx29H (mm)
Required:
The Turnigy Trailblazer XT is a high powered 1/5 4WD racing truck thats ready to dominate the track! With its powerful 14.8V 80A brushless system pre-installed, this truck has plenty of power to take home the win.
Large oil filled shocks, aluminum alloy drive shafts, 3mm 6061 T6 aluminum chassis, front/rear anti-sway bars, and sealed ball bearings all the way around shows that this truck means business!
It comes fully pre-assembled, and almost ready to run. Just add your own 2.4gHz radio system, 14.8V batteries (2 x 7.4V) and this truck is ready to race!
Features:
- Ready to Run (just add your own batteries)
Specs:
Length: 670mm
Width: 430mm
Height: 230mm
Wheelbase: 480mm
Tire Size: 150x70mm
Ground Clearance: 70mm
ESC: EZRUN-80A
Required:
2CH Radio System
It comes fully pre-assembled, and just requires your own 2CH radio system and batteries to get this truck running.
Features:
Specs:
Length: 504mm
Width: 385mm
Height: 188mm
Wheelbase: 335mm
Tire Size: 145x70mm
Servo: Std High Torque MG (9KG)
Required:
2ch Radio System
