Discussione: anderson m5
Vecchio 08 settembre 11, 09:48   #11 (permalink)  Top
Guingia-91
L'avatar di Guingia-91
Data registr.: 27-08-2010
Residenza: Modena
CIAO RAGAZZACCI!
Grandi Novità!
ho contattato via mail la anderson model e mi son fatto tolgliere qualche dubbio!
ho chiesto quali pessi fossero in carbonio e quali fossero solo estetici e l'esito (come immacinavamo) è stato questo:
Carbonio
#M5S9370 - Carbon Main Frame ::: ANDERSON MODEL CO., LTD :::
This is Carbon material in black
#M5S9371 - Carbon Upper Frame ::: ANDERSON MODEL CO., LTD :::
This is carbon material in black
#M5S9372 - Carbon Rear Frame ::: ANDERSON MODEL CO., LTD :::
Carbon-Look
#M5S9373 - Rear Arm (Carbon Texture) ::: ANDERSON MODEL CO., LTD :::
This is not carbon, it is plastic but print with Carbon look
#M5S9374 - Front Wheel (Carbon Texture) ::: ANDERSON MODEL CO., LTD :::
This is not carbon, It is plastic but print with carbon look
#M5S9375 - Rear Wheel (Carbon Texture) ::: ANDERSON MODEL CO., LTD :::
This is not carbon, it is plastic but print with Carbon Look
#M5S9376 - Front Shock Body (Carbon Texture) ::: ANDERSON MODEL CO., LTD :::
#M5S9377 - Brake Disc (Carbon Texture) ::: ANDERSON MODEL CO., LTD :::
This is not carbon, it is plastic but print with carbon look
#M5S9378 - Handle with Muffler (Carbon Texture) ::: ANDERSON MODEL CO., LTD :::
#M5S9396 - Bike Stand (Carbon Texture) ::: ANDERSON MODEL CO., LTD :::
#M5S9397 - Battery Case (Carbon Texture) ::: ANDERSON MODEL CO., LTD :::
Carbon-Silver
#M5S9407 - Carbon Main Frame (Silver) ::: ANDERSON MODEL CO., LTD :::
This is carbon material in black color (qui immagino si sia confuso e intendesse silver)
#M5S9408 - Carbon Upper Frame (Silver) ::: ANDERSON MODEL CO., LTD :::
This is carbon material in silver color
#M5S9409 - Carbon Rear Frame (Silver) ::: ANDERSON MODEL CO., LTD :::
la seconda domanda è stata:
-is the black carbon fibre more resistant than the silver carbon fibre?
They are about the same durable, just some people like black color, some people like silver color.
e in fine l'ultima domanda:
what is this part?
and how does it work?
#521602 - Receiver Noise Capacitor ::: ANDERSON MODEL CO., LTD :::
This is a capacitor to plug into the ESC if you use the motor which has higher KV more than 4900kv, then plug this capacity is better,If your motor KV is under 4900kv, it is no need to use this capacitor.
Guingia-91 non è collegato   Rispondi citando
