Vecchio 23 giugno 11, 16:13   #5 (permalink)  Top
milan
L'avatar di milan
Data registr.: 11-01-2009
Residenza: bologna
Originalmente inviato da qusimano Visualizza messaggio
grazie ragazzi,a questo punto mi sa che cambio elicuccia(magari ci rientrerei nei 12A ma mi avete fatto venire il dubbio,sicuramente consumeei di meno con una 4x5)
chiedo l'intervento di uno shamano dell'amperaggio,avrei anche un esc da 18A per stare sicuro ma preferisco sfruttare quello da 12,piu leggero e già "connettorato"
va su un depronuccio f22 che preferisco non appesantire troppo
con la 4x7 che ci potrei fare? un mini modellino da 3d? piu passo equivale a piu trazione giusto o sbagliato?
I dati sul sito dicono :
AX-1806N-2500
Micro brushless motor
Factory Spec.
Kv: 2500rpm/v
Lipo Range: 2-3 cell
Suggested prop: 5x3
Best current range: 3~8A
Weight: 19g
Shaft: 3mm
I commenti di chi lo ha comprato :
ome made thrust stand, and Watts up meter used for the below numbers, all props are GWS.
3s:
4X4 was to much, amps went high quick
4X2.5 280g 8A
2s:
5X3 225g 6.4A
4X4 130g 6A
5X4.3 240g 8A
I use this with the 5X4.3 on 2S and 4X2.5 on 3S, neither of which make motor hot (just warm). Using it on 2 small foamies, AUW 170g & 220g and obviously getting vertical with both! Great value.
1 comment. Reply..
Overall Rating
Tad Leake
likes
Value UNRATED
Quality UNRATED
20 thumbs up!
This is a great little motor, allthough the can came off of one of the three that i bought it was easily fixed with a little red locktite. The magnets on this motor are very strong, stronger than most motors twice its size. The windings are good, even if theres only a couple of them. The circut board really helps save the wires. I put a GWS 6x5 RD or slow-fly prop and drew 5.5A on a 2s800mah and made 35 watts of power, with a 8x4.3 RD or slow-fly it made 40 watts at 7A on a 2s800mah but it started loading up and hesitating. I think it would handle a 7in. prop on a 2 cell pack. I put a 3s1000mah pack on it with the 6x5 RD prop and it sounded like the prop was going to break. I wouldnt recomend anything bigger than a 5 in. prop on 3 cell, I did run it with a 5x3 GWS DD prop and it ran great, nothing got warm at all.
No comments. Reply..
Overall Rating
steve levinski
likes
Value UNRATED
Quality UNRATED
8 thumbs up!
useing on a 7 1/2 ounce hawk plane I built,using Hobby city's AX1806N 2500 kv outrunner and 2 cell battery with the 6X3 folding prop from Hobby City
ORO25-00206-A
8 Amps wide open
52 watts of power
Also tested a GWS 6030 hyper drive Prop
on the same motor with 2 cell
7.50 amps
52 watts
Really good prop but had to drill it to fit my hobby city AX1806N 2500 Outrunner
I had broke so many props trying to get this plane to fly this folding 6X3 is going to save a lot of money and time
Motor is really good and the folding prop
Overall Rating
Gary Moyer
likes
Value UNRATED
Quality UNRATED
7 thumbs up!
I run this motor on a Smart Dart foamie with a 800 mAH li-po battery and it's simply amazing. How amazing? Vertical climbs, tail stands, outside loops, etc.. Great power and performance as flight times regularly exceed 15 minutes!
Definitely a must-have for all light-weight foamies.
Overall Rating
TFCaeroplanes.com
likes
Value UNRATED
Quality UNRATED
6 thumbs up!
I designed a mini Quickie style racer around this motor and this little gem makes it rip at over 70 mph.
Test results using Emeter:
3S Lipo
Apc 4.1 x 4.1
Blue Arrow 8A Esc med advance
19,200 Rpm
6.4 Amp
10.8V
Non ci vuole molto a capire che ( OTTO ) Ampere sono la massima corrente utile per questo motorino e quali eliche montare per stare nei limiti, senza tirare in ballo Drivecalc.
Umberto
milan non è collegato   Rispondi citando
