Vecchio 21 maggio 11, 16:59   #7 (permalink)  Top
John Doe
Sospeso
Data registr.: 13-09-2010
Residenza: Vicenza
Il secondo canale (AUX CH) è opzionale: serve a controllare l'accensione delle candele nei motori glow (default), ad attivare/disattivare la sincronizzazione dei motori, ecc.
5.0 Auxiliary Channel Mode Functions and Details
The ability to connect an Auxiliary channel to the device is included and this section explains the detail operation of how the device performs in each mode of AUX CH input functions. The following sections explains each mode in detail:
MODE1: No AUX CH
This is the mode the device should be set to if an AUX CH is not connected to anything. The device lets the throttle stick control servos below 1/5th stick. Above 1/5th stick the devices moves the servos to that position and then synchronizes the engines. If the stick is moved the process is repeated.
http://www.troybuiltmodels.com/ns/ma...ync_manual.pdf
Che radiocomando utilizzi?
John Doe non è collegato   Rispondi citando
