Discussione: aurora 9
Vecchio 09 marzo 11, 22:14   #6 (permalink)  Top
Modellismo Eur
L'avatar di Modellismo Eur
Data registr.: 25-09-2005
Residenza: Ardea (Roma)
Immagini: 12
Invia un messaggio via MSN a Modellismo Eur
Originalmente inviato da fagiolonano Visualizza messaggio
ciao a tutti..
se non erro da ieri è disponibile il nuovo upgrade del firmware dell'aurora..qualcuno ha provato ad effettuare un aggiornamento?
What's New in Firmware Version 1.08 (View Version 1.08 Manual Addendum)
Added Functions:
  1. Frequency check: You can now decide if you want the radio to ask you to confirm your model to transmit.
  2. Receiver Battery Low Voltage Warning Function: You can select the Low Battery Warning Alarm activation level.
  3. Volt sensor screen for use with "E" Sensor Station.
  4. Current sensor screen for use with "E" Sensor Station.
  5. Rudder -> Elevator: Now added for knife edge flight and includes the "Adjust function" feature for easy in flight fine tuning
  6. Travel Limit: Allows a master EPA to be set so that no matter what mixes influence the servos, so they will not overdriven.
Improved Functions
  1. Battery Warning setting Function for telemetry: The Low Battery warning screen is now accessible even when receiver is not on.
  2. Aileron Differential: Simplified with single setting added for basic set up
  3. Camber Mix: Improved functionality and flexibility
  4. New Larger timers for easier monitoring
  5. EZ View telemetry monitoring: New screens offer larger text on telemetry functions like Speed, Altitude, RPM, and temp with recorder maximums on all but RPM.
Other Improvements
  1. When Throttle lock is activated by the toggle switch, the Touch lock function (Throttle lock by touch screen) will not be available and screen now shows throttle lock status.
  2. When a specific model is reset, the model name & model type will remain while the model data will be set back to factory default.
  3. Warning at start-up (Check frequency, High Throttle, Abnormal Flight condition warning) can be applied to all models at the same time.
  4. The B-Fly (Butterfly/Crow) function has been improved. The servo movement has been increased for more travel without the use of the adjust function setting.
  5. Flap-Control function has been improved. "Flaps up" will correspond with the slider or switch in the up positions, "Flaps down" will correspond with the slider or switch in the down position. (Opposite to V1.07 or earlier.)
  6. "Speed" of motor control on Servo monitor screen has been normalized when the RF is off.
  7. By pressing the "Exit Icon" (door icon) for 2 sec., the screen will return to the home screen. This saves having to hit the icon multiple times to back out of a menu.
  8. Models will scroll in groups of 4 ( one page.) Currently, scrolling is one by one.
  9. The EXPO has been modified to be more aggressive for more precise control when flying with high/3D control surface throws.
To get full use of your updated Aurora 9 you must also upgrade the Spectra 2.4 Module and Optima 7 & 9 Receivers to Firmware version 2.0
Aurora 9 v1.08 Update - Hitec RCD
Modellismo Eur non è collegato   Rispondi citando
