Discussione: t-rex 700E o f3c???
Vecchio 15 dicembre 10, 22:16   #7 (permalink)  Top
maRRRco
L'avatar di maRRRco
Data registr.: 13-06-2009
Residenza: Palermo
grazie per la correzione
effettivamente quando ho letto le specifiche tutto dava a pensare che fosse in carbonio, invece è solo ricoperta
dovrebbe essere più solida ad ogni modo e meno flettente
insomma sono piccole cose che nel complesso lo rendono un po' più adatto all'f3c, nulla di sconvolgente dalla versione elettrica
e quindi si presume prestazioni ottime
nessuno lo ha provato?
ps queste le specifiche
Features
1.Utilizing F3C competition helicopter design concepts, encompassing superior straight tracking ability, excellent static stability, resistant to wind gusts, and ultra precise control response.
2.All aluminum high precision head assembly, with newly tuned mixing ratios, to easily execute maneuvers specified in F3C routines.
3.Precision CNC machined module 1 main gear for minimal noise and high energy transfer efficiency.
4.Newly designed one piece stainless steel main gear hub to improve rotational stability.
5.Precision CNC machined aluminum pieces including elevator servo mount, rudder servo mount, rudder control bell crank arm, vertical and horizontal fin mounts.
6.Brand new carbon flybar reinforcement tube design to improve flybar rigidity. Adjustable stainless steel flybar weights, combined with F3C specific carbon flybar paddles, to achieve superior stability characteristics.
7.High quality large pre-painted horizontal and vertical carbon tail fins for improvements in flight tracking stability and excellent visibility.
8.Brand new carbon tail control pushrod assembly utilizing 5mm carbon rods and metal jointers to improve tail control precision.
9.Special F3C landing gear to lower the center of gravity.
10.Newly tuned F3C carbon main blades for superior stability.
11.High quality pre-painted fiberglass canopy, with improved aerodynamic efficiency and increased coverage to reduce wind resistance. The larger size enables improved visibility during flight.
12.Total pitch range of +/- 12 degrees for excellent position fixing precision and flight performance.
13.Innovative sliding battery tray rails imbedded into the 3K side frames, allowing for quick battery access as well as battery protection. In addition, the system improves the overall rigidity of side frames, as the same time raising the center of gravity.
14.Top mounted ESC platform to take advantage of main blades airflow for effective cooling.
Ultima modifica di maRRRco : 15 dicembre 10 alle ore 22:22
maRRRco non è collegato   Rispondi citando
