Vecchio 03 novembre 10, 00:08   #13 (permalink)  Top
faustog_2
L'avatar di faustog_2
Data registr.: 19-07-2008
Residenza: catania
Ci Sono Riuscito
OK FUNZIONA TUTTO
adesso riesco a leggere e scrivere attraverso la seriale USB, con il 16F628, in allegato metto una foto del circuito, mentre vcome software va bene anche quello che si trova in rete qui:
Bente Petersen's 9600baud 16F628 UART test circuit and program
Originalmente inviato da faustog_2 Visualizza messaggio
salve, lavorando con il 16F628 e tendando di ricevere ed inviare Byte da un software in java attraverso la porta seriale, trovo delle difficoltà:
Faccio una premessa, uso la MAx232 per trasformare il segnale EIA in TTL, poi uso il seguente include:
LIST
; P16F628.INC Standard Header File, Version 1.01 Microchip Technology, Inc.
NOLIST
; This header file defines configurations, registers, and other useful bits of
; information for the PIC16F628 microcontroller. These names are taken to match
; the data sheets as closely as possible.
; Note that the processor must be selected before this file is
; included. The processor may be selected the following ways:
; 1. Command line switch:
; C:\ MPASM MYFILE.ASM /PIC16F628
; 2. LIST directive in the source file
; LIST P=PIC16F628
; 3. Processor Type entry in the MPASM full-screen interface
; Revision History
;Rev: Date: Reason:
;1.01 13 Sept 2001 Added _DATA_CP_ON and _DATA_CP_OFF
;1.00 10 Feb 1999 Initial Release
; Verify Processor
IFNDEF __16F628
MESSG "Processor-header file mismatch. Verify selected processor."
ENDIF
; Register Definitions
W EQU H'0000'
F EQU H'0001'
;----- Register Files------------------------------------------------------
INDF EQU H'0000'
TMR0 EQU H'0001'
PCL EQU H'0002'
STATUS EQU H'0003'
FSR EQU H'0004'
PORTA EQU H'0005'
PORTB EQU H'0006'
PCLATH EQU H'000A'
INTCON EQU H'000B'
PIR1 EQU H'000C'
TMR1L EQU H'000E'
TMR1H EQU H'000F'
T1CON EQU H'0010'
TMR2 EQU H'0011'
T2CON EQU H'0012'
CCPR1L EQU H'0015'
CCPR1H EQU H'0016'
CCP1CON EQU H'0017'
RCSTA EQU H'0018'
TXREG EQU H'0019'
RCREG EQU H'001A'
CMCON EQU H'001F'
OPTION_REG EQU H'0081'
TRISA EQU H'0085'
TRISB EQU H'0086'
PIE1 EQU H'008C'
PCON EQU H'008E'
PR2 EQU H'0092'
TXSTA EQU H'0098'
SPBRG EQU H'0099'
EEDATA EQU H'009A'
EEADR EQU H'009B'
EECON1 EQU H'009C'
EECON2 EQU H'009D'
VRCON EQU H'009F'
;----- STATUS Bits --------------------------------------------------------
IRP EQU H'0007'
RP1 EQU H'0006'
RP0 EQU H'0005'
NOT_TO EQU H'0004'
NOT_PD EQU H'0003'
Z EQU H'0002'
DC EQU H'0001'
C EQU H'0000'
;----- INTCON Bits --------------------------------------------------------
GIE EQU H'0007'
PEIE EQU H'0006'
T0IE EQU H'0005'
INTE EQU H'0004'
RBIE EQU H'0003'
T0IF EQU H'0002'
INTF EQU H'0001'
RBIF EQU H'0000'
;----- PIR1 Bits ----------------------------------------------------------
EEIF EQU H'0007'
CMIF EQU H'0006'
RCIF EQU H'0005'
TXIF EQU H'0004'
CCP1IF EQU H'0002'
TMR2IF EQU H'0001'
TMR1IF EQU H'0000'
;----- T1CON Bits ---------------------------------------------------------
T1CKPS1 EQU H'0005'
T1CKPS0 EQU H'0004'
T1OSCEN EQU H'0003'
NOT_T1SYNC EQU H'0002'
TMR1CS EQU H'0001'
TMR1ON EQU H'0000'
;----- T2CON Bits ---------------------------------------------------------
TOUTPS3 EQU H'0006'
TOUTPS2 EQU H'0005'
TOUTPS1 EQU H'0004'
TOUTPS0 EQU H'0003'
TMR2ON EQU H'0002'
T2CKPS1 EQU H'0001'
T2CKPS0 EQU H'0000'
;----- CCP1CON Bits ---------------------------------------------------------
CCP1X EQU H'0005'
CCP1Y EQU H'0004'
CCP1M3 EQU H'0003'
CCP1M2 EQU H'0002'
CCP1M1 EQU H'0001'
CCP1M0 EQU H'0000'
;----- RCSTA Bits ---------------------------------------------------------
SPEN EQU H'0007'
RX9 EQU H'0006'
SREN EQU H'0005'
CREN EQU H'0004'
ADEN EQU H'0003'
FERR EQU H'0002'
OERR EQU H'0001'
RX9D EQU H'0000'
;----- CMCON Bits ---------------------------------------------------------
C2OUT EQU H'0007'
C1OUT EQU H'0006'
C2INV EQU H'0005'
C1INV EQU H'0004'
CIS EQU H'0003'
CM2 EQU H'0002'
CM1 EQU H'0001'
CM0 EQU H'0000'
;----- OPTION Bits --------------------------------------------------------
NOT_RBPU EQU H'0007'
INTEDG EQU H'0006'
T0CS EQU H'0005'
T0SE EQU H'0004'
PSA EQU H'0003'
PS2 EQU H'0002'
PS1 EQU H'0001'
PS0 EQU H'0000'
;----- PIE1 Bits ----------------------------------------------------------
EEIE EQU H'0007'
CMIE EQU H'0006'
RCIE EQU H'0005'
TXIE EQU H'0004'
CCP1IE EQU H'0002'
TMR2IE EQU H'0001'
TMR1IE EQU H'0000'
;----- PCON Bits ----------------------------------------------------------
OSCF EQU H'0003'
NOT_POR EQU H'0001'
NOT_BO EQU H'0000'
NOT_BOR EQU H'0000'
NOT_BOD EQU H'0000'
;----- TXSTA Bits ----------------------------------------------------------
CSRC EQU H'0007'
TX9 EQU H'0006'
TXEN EQU H'0005'
SYNC EQU H'0004'
BRGH EQU H'0002'
TRMT EQU H'0001'
TX9D EQU H'0000'
;----- EECON1 Bits ---------------------------------------------------------
WRERR EQU H'0003'
WREN EQU H'0002'
WR EQU H'0001'
RD EQU H'0000'
;----- VRCON Bits ---------------------------------------------------------
VREN EQU H'0007'
VROE EQU H'0006'
VRR EQU H'0005'
VR3 EQU H'0003'
VR2 EQU H'0002'
VR1 EQU H'0001'
VR0 EQU H'0000'
; RAM Definition
__MAXRAM H'01FF'
__BADRAM H'07'-H'09', H'0D', H'13'-H'14', H'1B'-H'1E'
__BADRAM H'87'-H'89', H'8D', H'8F'-H'91', H'93'-H'97', H'9E'
__BADRAM H'105', H'107'-H'109', H'10C'-H'11F', H'150'-H'16F'
__BADRAM H'185', H'187'-H'189', H'18C'-H'1EF'
; Configuration Bits
_BODEN_ON EQU H'3FFF'
_BODEN_OFF EQU H'3FBF'
_CP_ALL EQU H'03FF'
_CP_75 EQU H'17FF'
_CP_50 EQU H'2BFF'
_CP_OFF EQU H'3FFF'
_DATA_CP_ON EQU H'3EFF'
_DATA_CP_OFF EQU H'3FFF'
_PWRTE_OFF EQU H'3FFF'
_PWRTE_ON EQU H'3FF7'
_WDT_ON EQU H'3FFF'
_WDT_OFF EQU H'3FFB'
_LVP_ON EQU H'3FFF'
_LVP_OFF EQU H'3F7F'
_MCLRE_ON EQU H'3FFF'
_MCLRE_OFF EQU H'3FDF'
_ER_OSC_CLKOUT EQU H'3FFF'
_ER_OSC_NOCLKOUT EQU H'3FFE'
_INTRC_OSC_CLKOUT EQU H'3FFD'
_INTRC_OSC_NOCLKOUT EQU H'3FFC'
_EXTCLK_OSC EQU H'3FEF'
_LP_OSC EQU H'3FEC'
_XT_OSC EQU H'3FED'
_HS_OSC EQU H'3FEE'
LIST
Ho il sospetto che il problema stia nell'oscillatore interno... qualcuno ha avuto lo stesso problema?
faustog_2 non è collegato   Rispondi citando
