Discussione: Fail Safe
Vecchio 24 agosto 10, 10:48   #10 (permalink)  Top
rugrug
L'avatar di rugrug
Data registr.: 08-03-2010
Originalmente inviato da laser02 Visualizza messaggio
Gas a zerò!
Saluti
grazie
dunque tutti gli altri li posso lasciare su INH?
After Connection
When the transmitter is turned on, and after the receiver connects to the transmitter, normal control of all channels occurs. After the system makes a connection, if loss of signal occurs, SmartSafe drives the throttle servo only to its preset fail-safe position (low throttle) that was set during binding. All other channels hold their last position. When the signal is regained, the system immediately (less than 4 ms) regains control.
quindi c'è già un sistema che taglia il gas anche senza impostare manualmente il Fail Safe di Thro nel menu specifico?
