Discussione: problema simjet 1700
Vecchio 22 giugno 10, 22:31   #4 (permalink)  Top
filo77
L'avatar di filo77
Data registr.: 18-03-2010
Residenza: Krimini
ecco i parametri
-START UP PARAMETERS-
-pump start point:auto+1 (precedentemente auto+3)
-pump start point: 001 (precedentemente 006)
-glow plug power:35
start gas adjust:100%
low batt volts:6.0v
starter power at ignition:060
ignition max rpm:5000
ignition min rpm:3000
preheat time:2.0s
rpm gas off:20000 rpm
starter power at preheat:017
rpm 100% starter power:15000
rpm off starter:20000
rpm to reconnect starter:18000
starter mode: auto-gas
NORMAL RUN PARAMETERS
full power speed:124000rpm
idle speed:33000rpm
stop speed:25000rpm
start min temp:100°c
max temperature:800°c
accelleration delay:015
deceleration delay:015
stability delay:100
pump limit:1000
filo77 non è collegato   Rispondi citando
