16 aprile 10, 14:28
#50 (permalink)
Top |
| User
Data registr.: 06-12-2008 Residenza: novafeltria (rn)
Originalmente inviato da daredevil align ha da fare i conti con questo:
Features
Easy set up for first-time users
Flybarless stabilization with piro-compensation
Built-in tail gyro, supporting most all tail servos by name in the setup software
Supports use as a 9-channel receiver core when used with 2.4 GHz
satellite receivers (two dedicated Sat-RX ports)
Works with Digital or Analog swash servos
Suitable for 120, 135/140, and 90 degree eCCPM, as well as mCCPM swashplates
Works with 2,3,4, or 5 blades, with phase trim adjustable to +-90°
Swash Ring anti-binding algorithm
Internal swash mixing, for accurate control
Supports radios with either 1024 or 2048 servo steps, and 22ms or 11ms frame rates
Can also be used with traditional R/C receivers
Expansion port for future accessories such as GPS
38 x 30 x 14 mm, 17 grams
8.5 volt capable
Optional 20 amp external power bus (included) for larger than 50-size and nitro helis (15 grams). Make brownouts a thing of the past!
3-axis accelerometer + 3 gyros, allowing self-leveling
High-power 32 bit processor (for future upgradeability)
Expansion port for GPS or a third sat-receiver
Up to 10 servos (one tail servo, 4 digital swash servos, Throttle, and 4 Aux channels)
Port for a remote indicator LED , which you can mount outside of the canopy
Built in micro-SD card (2 GB flight-data logging)
Built in USB mass storage device - Connect the unit to your computer without having to install drivers
Flight data logs can be played back on your PC with analysis of tuning and heli health
Compatible with the Skookum SK-LCD terminal
Existing SK360 setup files can be easily up-converted for the new unit | e si..e nn solo questo..ma anche il v-staby..io di skookum ne ho 2 e sto aspettando il 3..penso che ora come ora sia il top di tutti il 720...(secondo me)  |
