Vecchio 30 gennaio 10, 21:23   #2 (permalink)  Top
loekie
L'avatar di loekie
Data registr.: 24-12-2008
Residenza: Lissone - Seregno - Monza
Originalmente inviato da lombardoa Visualizza messaggio
Queste informazioni si trovano nel manuale della ricevente... oppure sul sito internet. Quello che vi capita accade quando il sistema rileva problemi sull'alimentazione.Come falsi contatti oppure perdita di potenza del bec...Dopo il volo è importante verificare se questo lampeggio è attivo.Se si, verificate il collegamento elettrico, le batterie ecc... giusto per evitarela perdita del controllo del vs. aeromodello. Saluti....ArtPs: A tal riguardo eccovi un copia-incolla: QuickConnect With Brownout DetectionYour AR7600 features QuickConnect with Brownout Detection.• Should an interruption of power occur (brownout), the system will reconnect immediately when power is restored (QuickConnect).• The LED on the receiver will flash slowly indicating a power interruption (brownout) has occurred.• Brownouts can be caused by an inadequate power supply (weak battery or regulator), a loose connector, a bad switch, an inadequate BEC when using an electronic speed controller, etc.• Brownouts occur when the receiver voltage drops below 3.5 volts thus interrupting control as the servos and receiver require a minimum of 3.5 volts to operate.How QuickConnect™ With Brownout Detection Works• When the receiver voltage drops below 3.5 volts the system drops out (ceases to operate).• When power is restored the receiver immediately attempts to reconnect to the last two frequencies that it was connected to.• If the two frequencies are present (the transmitter was left on) the system reconnects typically within one second.QuickConnect with Brownout Detection is designed to allow you to fly safely through most short duration power interruptions, however, the root cause of these interruptions must be corrected before the next flight to prevent catastrophic safety issues.Note: If a brownout occurs in flight it is vital that the cause of the brownout be determined and corrected.
Be io non escludo niente di quanto tu scrivi...vedrò di verificare il verificabile....
Il fatto è che è da più di un mese che non volo con il modello che ha la suddetta ricevente, ed elettronica....
Al momento non mi fido a volarci fino a che non capisco dove è il vero problema. Faccio delle prove ogni giorno ma oggi ho realizzato che è tutto casuale....il che mi fa pensare ad un guasto alla ricevente....
Accendo la radio, poi la ricevente, attendo....e... be il collegamento cè....
Accendo la radio, poi la ricevente....attendo...nessun link.....non funziona niente....
Accendo......poi la ricevente....link satellite lampeggiante....funziona tutto....
muovo il satellite......il lampeggio aumenta, ma funziona tutto...poi aspetto il lampeggio rallenta, ma funziona comunque tutto....Spengo.
Riaccendo...ed ancora non si muove niente....
Sostituisco il cavetto del satellite, ma il risultato è il medesimo.....
Un paio di settimane passate avevo cambiato anche il satellite....
Due settimane fa ho cambiato il regolatore...idem...stesso problema...
La lipo è ok....idem per i collegamenti....
Certo io non sono un elettronico, per cui non posso fare verifiche con strumenti adeguati.....
La stessa radio la sto utilizzando su un Protos in costruzione con una ricevente piu piccola, ma non ho per ora nessun problema....
Ripeto tutto questo prima della pausa di un mese non succedeva....
Quello che mi sconcerta e che puo essere piu di un problema è che il difetto non ha una sequenza logica, di conseguenza potrei avere la sfiga che se mando tutto in assistenza, potrebbe tornarmi indietro che in pratica non la guardano nemmeno....
Comincio a pensare all'acquisto di una nuova radio....SENZA SATELLITI....
Giuseppe
loekie non è collegato   Rispondi citando
