Vecchio 03 dicembre 09, 22:46   #25 (permalink)  Top
ryan-j
L'avatar di ryan-j
Data registr.: 30-09-2006
Il manuale dice di staccare il filo ROSSO:
"If you are using more than ten NiMH/NiCad cells, more than
3 LiPo cells, or your power consumption is excessive, you
must disable the BEC and use a separate power source for
the receiver. Disable the BEC by cutting or removing the
red wire from the servo connector on the controller. Do not
use the BEC to power other items on your plane such as
lights."
http://www.castlecreations.com/suppo...User_Guide.pdf
r.
ryan-j non รจ collegato   Rispondi citando
