Discussione: Coda oscillante
Vecchio 12 novembre 09, 12:47   #1 (permalink)  Top
fermat55
Data registr.: 24-03-2007
Residenza: padova
Ho trovato questo:
FUTABA GY240 GYRO SPECIFICATIONS
Type: Micro Heading Hold Gyro
Sensor: SSM AVCS
Weight: 25 grams (0.88 oz)
Dimensions (WxLxH): 27 x 27 x 19mm
Gain Setting: Manual on gyro only
Mode Setting: Rate or Heading Hold – Switch selectable on gyro
Operating Voltage: 4.8 VDC (Needs a voltage regulator (6 VDC) if using higher than 4.8v battery packs)
Reversing Switch: Yes, on gyro
Limit Trimmer: None
No Fast Digital Output – The GY-240 works best with analog tail servos.
fermat55 non è collegato   Rispondi citando
