Ho trovato il tutorial (credo) di cui parlava Merengue e ne riporto la
parte pertinente alla mia domanda.
14.11 HOW TO ASSIGN A DIGI-ADJUSTER TO A CONTROL
Although the Digi-Adjusters (DA) can be used to alter numerical values in
many places on the EVO (even while flying), they cannot be assigned
directly to a control.
However, by using the fixed value properties of either the spoiler or the
flap controls which can be assigned to one of the DAs, a mixer can be
made that will enable any channel to be moved directly from the DAs.
This scenario assumes that either the flap or the spoiler channel is not
being used in the plane.
Create the following mixer:
DA+Rud+
Rudder ---- |
Spoiler ---- |
Assign the DA+Rud+ mixer to the rudder servo.
In the MIXER main menu adjust the DA+Rud+ mixer to these initial values:
DA+Rud+
Rudder ---- 100%
Spoiler ---- 100%
In the CONTROLS menu, select the spoiler control and assign the fixed
value field to the right DA by highlighting the numerical value, pressing
the DA button at the bottom of the transmitter and then pressing the
right DA.
Comments
Since the DAs can be used to adjust fixed values and since the channel
whose fixed value is being altered is listed as an input into the mixer
(the spoiler channel), the rudder servo in this example will move when
the DA is turned.
Some drawbacks to using this method are that a free spoiler or flap
channel must be available, the DAs don't have a mechanic stop like
a conventional slider and the DA click "steps" cannot be adjusted for
greater or lesser servo travel as a result of the DA being turned.
This scenario may limited feasible applications due to the limitations
listed above.
Aiutatemi per favore a capire se sto ragionando giusto e se lo schema
logico della programmazione cui ho pensato è attuabile:
creo un nuovo modello basato sul template che più mi aggrada,
in questo caso "HELImech"
Faccio tutte le solite normali configurazioni per fare andare fortisssssimo
in 4 o 5 D (
) il mio eli, seguendo l'impostazione del template della radio.
A questo punto creo un nuovo mixer che chiamo COPILOT al quale
associo un solo canale (posso farlo vero ? ... invece che assegnarne due),
nello specifico il canale 7.
Poi seguo le istruzioni del tutorial che ho riportato poco sopra per assegnare
tale mixer al digi3d.
E faccio la stessa cosa per il canale 8 scegliendo ovviamente un
nome diverso per il mixer.
Ho ottenuto lo scopo ? Ovvero 8 canali proporzionali comandabili sulla
radio ?
Grazie mille per il prezioso aiuto.
Ciao,
Daniele
