Ciao, il venditore mi ha subito mandato per mail delle istruzioni eccole:
Here is some instructions on the install of the brushless motor, it is from the manufacturer, let me know if you need more help. 2. 4 cables extend out to brushless motor, 3 of them (Thick ones) in color red, white, black connect to the brushless motor. Before doing this, the cable need fix the small coper tube, which were put together with brushless motors. Remove the small cap for another two cable (Thin) 3. 3 cables extend out to the battery, 2 of them (Thick ones) connect to the battery, please not the correct '+' and '-'. Black to black, white to white. Before doing this, the two cables need fix the suitable connector, in order to connect to the battery easily. You can see there are another 3 thin cables which was paste together at the same side. Plug the 3cables connector to CH3 of receiver in Dragonfly 36 heli. Regards
Non mastico benissimo l'inglese ma mi sembra di aver fatto tutto come dice lui giusto?
Aiuto... Sono qui con l'elicottero nuovo davanti e non posso farlo andare...
