Discussione: AXI 2826/12 ribobinato
Vecchio 09 ottobre 08, 22:48   #10 (permalink)  Top
Gianka
L'avatar di Gianka
Data registr.: 20-05-2004
Residenza: Gruppo Aeromod. Carignano - To
Originalmente inviato da ron_van_sommeren Visualizza messaggio
Have you tried it with another type/make controller? Same problem?
A list of controllers and their max. rpm for given number of magnetpoles. Maybe you are hitting the maximum?
Home-built Brushless Motors and Models
-> motor building info
-> ESC Max. RPM Limits
CW and CCW justs indicate different winding directions, it has nothing to do with a clock. One could also use black<>white or (+) <> (-) or hot<>cold etc. to inidicate opposite winding directions. 'We' always use uppercase<> lowercase characters AaBb ... etc
All AXI's use LRK or dLRK, they only differ in size and number of winds.In the case of dLRK, make sure whether the number of winds is given per tooth or per two (neighbouring) teeth! More axi rewinds:
Rewinding of an Axi with questions - RC Groups
Rewinding an axi motor for higher KV? - RC Groups
Vriendelijke groeten Ron
• brushless motor building tips & tricks
• diy brushless motor discussion group
• int. electric fly-in, Nijmegen/Winssen
• Drive Calculator download & discussion group
Hi Ron
today I make a test with 3c lipo 2250 and 13x8 folding propeller - the motor run perfectly with charge and no have exitation for all stick. Wattmeter record at 10V = 27A that s perfect.
Pull out propeller I look with attention the belt turning and I note a very little swing. It s possible that are a mecanichal and not electric problem. With the charge of propeller run without slowing down.
In next days I can change shaft and ball bearings to see the swing stop.
I any case thanks for info.
Gianka
Gianka non è collegato   Rispondi citando
