Ciao, volevo segnalare un thread su rcgroups.com, http://www.rcgroups.com/forums/showthread....4&page=10&pp=15 da cui stanno uscendo le magagne della nuova fantastica 14MZ e anche della sua progenitrice T9Z... roba da mettersi le mani nei capelli, a dire poco... qualche estratto: "The problem I have with the 14 MZ is that every potentially good feature seems to have a downside. It's like opening the chocolate box to find it half empty... It has a 2.2 AH Lithium battery, but can only manage a 2-3 hours on a single charge. Not good enough for soarers. How can Futaba have the cheek to trumpet battery duration as a strong point?? It has a technically complex synthesiser system - but no scanner. It has interchangeable RF modules - but you can't change them because of the stoopid region locking. <-- NON SI PUO' CAMBIARE MODULO (E QUINDI BANDA) NONOSTANTE ABBIA IL MODULO RIMOVIBILE!! It has so-called 'real time servo response' - but takes several seconds to boot up from cold (according to the manual). It uses Windows CE for the user interface, but the UI looks like MS-DOS with buttons, and doesn't appear particularly well designed." ... e ancora: (questa è bellissima) "An outright advertising lie by Futaba. The time it quotes for its "real-time response" is simply the same time as a decades old PPM radio. They are squeezing more channels into that time, but the elevator, aileron etc are not going to respond any faster to the control sticks than they would on a mid-1970s PPM radio. Is that something they should be claiming is a new advanced feature in their adverts? It's really an admission that its other PCM radios such as the 9Z are NOT real-time response. " ancora un pò: Dalla FAQ ufficiale della 14MZ: "My radio's Windows system crashed!! Now what do I do? I turned my radio off after setting up my plane and when I flipped it back on, there were no settings in it at all! If you shut down your radio and did not give it the full time to completely shut itself down (see page 25 of your manual) then you will need to re-enter all of your model data. It's basically like a typical computer, and needs to go through the "SAVE" mode at shutdown. " e ancora: "The 14MZ is advertised as having 7 wing types available, but when I go into set my model up I only get 4 showing? What's wrong with my transmitter? There are 7 wing types available to you, only in PCM2048 G3, as in this mode there are 12 linear channels available. Only 4 wing types are available in PCM1024 and PPM/FM mode, as only 8 linear channels are available. " ...a voi le conclusioni... personalmente sono deluso _M_ |
Ciao, io non possiedo quella radio, premetto, ma mi sono scaricato il manuale di istruzioni. :wink: Personalmente ritengo che sia solo luccichio
alla fin fine non fa niente di più utile di una Multiplex Profi 4000, almeno in ambito aerei/veleggiatori. Il fatto di montare windows.. al di là di battute sullaffidabilità del sistema, non vedo che vantaggi possa dare
ascoltare gli mp3 ?? Penso che il vero salto tecnologico si avrà,eventualmente, con i 2,4 GHz e con apparati in grado colloquiare con la ricevente sul modello: questo significa acquisizione dati in real time, autodiagnostica ecc. ecc. E tutto il sistema funzionerà in digitale, dallencoder sullo stick fino a quello sul servo. Ciao, Paolo. B) |
L'unico vantaggio degli MP3 è per coloro che volano sincronizzando il volo con la musica. Possono usarlo durante gli allenamenti senza disturbare gli altri con i quali volano :wink: e senza dover usare uno stereo ogni volta che cambiano campo. Questa è l'unica conclusione a cui siamo giunti con alcuni colleghi modellisti :wink: Tutto il resto, penso che questa radio può essere utile soltanto a chi può davvero sfruttarla. E cioè solo a 10-20 modellisti in tutta Italia (Benincasa, Silvestri ecc. ) :wink: Per gli altri, apparte lo sfizio tecnologico, sono soldi letteralmente buttati :wink: |
E... scordatevi di comprarla negli USA o Hong Kong su eBay..... Futaba have implemented a region locking feature in the transmitter and RF module firmware. As I understand it, a region ID is stored in the Tx at the factory, and subsequently only RF modules valid for that region will operate correctly when plugged in. The only reason I can see for tx firmware based region locking is to stop people buying the set in one region and re-selling it in another. Whatever the reason, the 14MZ comes out of the factory with one of the 'features' namely interchangeale RF modules, effectively crippled. Mike Ciao, Paolo. B) |
ho letto alcuni FAQ, uno mi ha icuriosito, la risposta diceva che la maggior parte dei problemi sono dovuti ad un cattivo uso da partye dell'operatore ovvero: "but it's due mainly to operator problems when the user turns off the transmitter" per cui, consiglio a chi ha una t14 di contrarre un contratto di manutenzione con ditta informatica, e di dotarsi di antivirus e firewall!!!! :lol: :azz: |
Piuttosto, viste le difficoltà che si incontrano se la si spegne nel modo scorretto, e considerata la scarsissima durata della lungimirante batteria al Litio......meglio dotarsi di gruppo elettrogeno :wink: |
Non è assolutamente vero: è utile per chi fa acrobazia, dato che scandisce le figure da fare (ti sei mai chiesto cosa ci stia a fare il tizio dietro il pilota nelle gare di f3a e simili? http://www.mfc-kleve.de/assets/images/F3A2004-034.jpg ) e, se la cosa è stata pensata in modo un po' lungimirante, anche per chi fa gare in cui conta il tempo: nella F-3J molti si dotano di cronometri parlanti per sapere quando iniziare a scendere e quando iniziare l'atterraggio vero e proprio. Il modulo vocale lo avevano gia' fatto mi pare per la MC24 della Graupner e la Profi 4000 della MPX..... radio eccezionali e che sono state veramente innovative, al tempo della loro uscita... La T-14 mi ricorda qualche anno fa quando furono presentati i frigoriferi e le lavatrici con connessione ad internet: ganzata tecnologica assolutamente inutile... Simone |
Ma sbaglio o hai scritto le mie stesse cose? :blink: :rolleyes: |
Adesso non mi direte che una Hitec 4 canali base è meglio della t14 o della t9zap!! :angry: Come sempre quando esce una novità molto diversa dalle solite,come la t14 tutti cercano di trovare i difetti,in quanto i pregi sembra sempre che siano utilizzabili solo da pochissimi eletti nel mondo..in quanto la maggior parte dei piloto della domenica non sa neanche a cosa servano gli esponenziali... Io non la penso così..possiedo al momento una t9wc2 della quale sono contentissimo e che sfrutto quasi al 100% sia con gli aerei che con gli alianti che con gli eli..uso 4/5 fasi di volo con curve motore dedicate,esponenziali,ecc,ecc e miscelazioni varie completamente diverse per ogni fase.. La mia "Vecchia" t9 con il pacco di batterie originali faceva si e no 2 ore e mezza di funzionamento..adesso che le ho sostituite con pacchi da 2300mah ci faccio oltre 5 ore..non mi sembra un dramma prendere un pacco di scorta anche per la t14.. Per gli mp3 mi piacerebbe averli anche sulla mia per il discorso precedente,Musica + figure acro.. Al momento preferisco aspettare ad acquistare per vedere se ha dei problemi(le prima serie di tutto ne hanno..)e che scenda un pò il prezzo..poi sicuramente la prenderò e la sfrutterò al meglio!! B) |
Mere, non è solo una questione di trovare il pelo (che sarebbe anche giusto, dato il prezzo). E' anche una questione di analizzare cosa c'è di veramente nuovo in una radio come la 14mz. Quando uscirono le varie mc-24, profi 4000 ecc, come diceva Simone, erano veramente delle radio innovative, nel senso che permettevano di fare cose prima impossibili con le radio precedenti. Sono ormai passati (ben) più di 10 anni da allora, e da un prodotto di punta che uscisse oggi ci si aspetta (almeno, IO mi aspetto) parecchi aspetti di innovazione "pura". Invece la 14mz, a parte le figate "estetiche", non fa nulla di più che non faccia la tua 9z o comunque una profi 4000. In più ha tutti queli problemucci tipici del software fresco di fabbrica (leggi BUG). Metti in conto anche che le ditte di RC come futaba & co sono lente ammazzate a fare aggiornamenti, migliorie, ecc... stronzi come sono, non è improbabile che in futuro, per avere il software messe "a posto", ti costringano a ricomprare la stessa radio in versione "super", come loro consuetudine. :blink: :rolleyes: Per quanto riguarda la tua 9z, tanto di cappello, è un'ottima radio, è giustissimo che la sfrutti al 100%. Vuol dire che hai speso bene i tuoi soldi! Approposito della storia degli esponenziali, mi fai venire in mente proprio un modellista che ha la 9z (prima versione) e ogni domenica ne decanta le mistiche potenzialità... pensa che ha scoperto gli esponenziali solo da qualche settimana! (sulla FF7, sulla 9Z non è ancora riuscito a trovarli!!)... i flight mode "..che?!? si mangiano?!" :P :D Alla prox _M_ |
A parer mio la 14MZ,è una radio splendida, mi ci sto trovando benissimo, è un pò difficile settarla con gli eli ma, con l'aiuto di altri che l'hanno acquistata da poco,sto cercando di arrivare al dunque... Ho uploadato sulla compact flash tutte le foto dei miei modellini, ho notato che i file audio supportati sono vma e wav ma spero che si possano lanciare anche gli mp3... Per quanto riguarda l'autonomia,beh tutti sanno che io sono un super volatore, da quando ho scoperto le lipo,atterraggio\volo\rivolo\riatterro..e via..Senza fermarmi mai.. :) Ho notato che la batteria da 2200mah, mi basta precisa precisa..Quando non ho più voglia di volare mi resta quasi sempre un 20% di carica, a volte pure meno, Vado a casa ed in meno di 2 ore è tutto pronto :) Dicerto acquistare un'altra batteria non sarebbe una cattiva idea ma al momento io questa la considero sufficiente... Riguardo a quanto detto quì sopra, non è assolutamente vero che non si possono cambiare i moduli, io all'inizio ne avevo ordinata una versione con due moduli RF, 35 e 40 mega,logicamente la frequenza è selezionabile dal menu per cui potevo controllare tutti i miei modellini..poi ho deciso di tenere il 40 mega che francamente mi pare quello più usato,anche perchè voglio sempre tenermi una seconda radio in valigetta e quindi ho optato per i 35 sulla ff9 super.. Il prezzo non è affatto alto per l'oggetto che è,secondo me quando si decide di comprare una radio seria, c'è poco da risparmiare,tanto quella resta..per tutti i modelli! Sono soddisfatto al 100% :) |
Forse il blocco in questione si riferisce al fatto di non poter installare il modulo a 72 MHz. su una radio "Europea" o, viceversa, di non poter installare i 35/40 sul modello "Americano" . La mia comunque è solo un'ipotesi .... B) Citazione:
Ti diverti forse a "disturbare" i vicini ?!?!? :D :D :D |
Tranne che non sia cambiato qualcosa nelle ultime versioni del software, sulla 14MZ non e' possibile cambiare banda di trasmissione, ovvero il modulo lo puoi sostituire ma se la banda e' diversa dall'originale non trasmette. Se uno vuole cambiare banda deve mandare la radio in assistenza per la riprogrammazione nella banda desiderata, cosi' mi confermarono l'anno scorso a Norimberga, cosi' e' scritto anche sul test su Modellistica. La cosa e' ovviamente fatta apposta per evitare l'acquisto all'estero del prodotto. |
Mi sembra una limitazione grossotta per un oggetto di questa portata .... Comunque sia, già come è successo per altri apparecchi in cui è stata implementata assieme alla parte elettronica una cospicua parte informatica (vedi i recenti cellulari) non credo che tarderà molto ad arrivare il solito "genietto" che riesce ad aggirare il problema a livello software. Dal punto di vista dell'utente finale non mi posso che augurare che cio accada il prima possibile, certi accorgimenti servono solo a limitare la concorrenza e mantenere i prezzi alti per far guadagnare i soliti noti, lo trovo un sistema alquanto antipatico oltre che controproducente, molti modellisti che usano radio di questo livello usano il doppio modulo, alla fine puo essere che qualche cliente lo perdano :D . |
Ogni ditta fa le sue scelte commerciali, ripeto magari nelle ultime versioni del software hanno cambiato idea ma ci credo molto poco. |
xo a questa radio manca qualcosa di moolto importante!!! proprio nessuno l'ha notato??? manca una sk ethernet o meglio wi-fi altrimenti come fa a fare il windows update??? :P cmq non disperate... qualcuno fara una bella distro linux x mz14 con firewall, kde e perche no mettiamoci pure il MaMe va... cosi tra un tetris e l'altro vi ricordate di far atterrare il modelllo :D :D Ovviamente scherzo cmq è un bel oggettino, ma come molti hanno gia detto in pochi riusciranno a sfruttarlo a pieno... X quello che riguarda i moduli dico solo una cosa se cè winzozz cè speranza, nel senso che sicuramente qualcuno trovera il modo di aggiornare il firmware col fai-da-te ciau |
Se ben ricordo ha una porta USB, ma il sistema e' blindato ovvero non c'e' accesso dall'esterno, come al solito servira' un'apposita chiave hardware/software. |
date tempo al tempo. anche la x box e la ps2 erano blindate. ricordate!!! ciao |
Probabilmente in italia il suddetto modulo costa anche di più, i prezzi tedeschi nel settore modellistico sono quasi sempre molto più convenienti.. Per la 72mhz, sicuramente avete ragione voi, NON LO DISCUTO, per cui non è dicerto consigliabile acquistare la radio negli stati uniti o ad hong kong, Io l'ho acquistata in germania sono convinto che,assieme alla spagna, resti il paese dove è possibile trovarla al prezzo più conveniente :) Ho deciso di optare per la 40mhz...ad ogni modo 40.685 non ce l'ha nessuno quì..ehehhehe senza volerlo ho azzeccato l'unico quarzo REALLY FREEEE :lol: |
Tanto che fate gli esperti, Windows in questa radio viene usato SOLO per gestire l'interfaccia grafica e quella audio. La parte che gestisce la radio vera e propria (il firmware per intenderci) è scritto in linguaggio proprietario (così come nelle vecchie radio Futaba). Sicuramente qualcuno prima o poi riuscirà a violare il blocco sulle frequenze, ma dopo aver speso 2.000 euro voglio proprio vedere chi è il fesso da invalidare la garanzia della radio piuttosto che rischiare un guasto che poi radiosistemi vi farà pagare a caaaaro prezzo :wink: Per Alex, complimenti per l'ottimo acquisto. Ora sei a livello di Silvestri e Martinucci che però questa radio non c'è l'hanno ma continuano a far volare i loro modelli a passo di musica :wink: |
WinCE infatti, come tutti gli OS, è soggetto a blocchi improvvisi e/o malfunzionamenti più o meno frequenti, a seconda delle versioni e dell'hardware dove è installato, utilizzarlo solo per la grafica e l'audio credo che implichi il fatto (ma potrei essere smentito dai fatti) che la radio comunque continua a trasmettere, indipendentemente da cosa succeda al sistema operativo, a tutto vantaggio della sicurezza. Sapete, un palmare od un cellulare si spengono ed al massimo si ricompone il numero che si stava chiamando, un modello in volo non può certo aspettare un "Reboot" del sistema :D . |
M |
| Tutti gli orari sono GMT +1. Adesso sono le 04:48. |
