Discussione: 1° modello
Vecchio 19 maggio 08, 08:41   #18 (permalink)  Top
tacchino
Guest
Messaggi: n/a
Originalmente inviato da atrexengine Visualizza messaggio
ho fatto quella domanda perche vorrei costruirmi un aereo piccolo a reazione tutto per me.............e possibile?????
possibilmente con pulse detonation engine atrex ad idrogeno....se qualcuno puo aiutarmi...............
sì, cerca con Google e troverai per esempio questo:
Amateur PDE Development
Unfortunately pulse detonation engines are probably not the sort of thing that is well suited to amateur development.
The risks of containment failure (ie: a catastrophic explosion that turns your engine into a grenade) and the difficulties involved in obtaining reliable detonation of readily available fuels make both dangerous and likely to be quite disappointing.
The sad truth is that you're unlikely to be able to coerce a mixture of gasoline and air or propane and air into true detonation using something you've built in your garage -- and if you do, the paramedics will likely have to take you away in a plastic garbage bag (that's if they can find all the pieces ;-).
  Rispondi citando
