Discussione: JR x9303 2.4
Vecchio 30 aprile 08, 15:52   #190 (permalink)  Top
Daytona
L'avatar di Daytona
Data registr.: 24-04-2008
Residenza: Cesena
Aileron Differential
Mi stò leggendo il manulae di questa magnifica radio e sono molto propenso a prenderla.
Per il momento ho capito praticamente tutto ma a pagina A-33 del manuale viene spiegato come usare AILERON DIFFERENTIAL e questo non l'ho propio capito...
ovvero:
When Ailerons are deflected, the Aileron that deflects
downward typically creates more drag than the Aileron
that deflects upward. If the difference in drag is great
enough, it will cause the aircraft to yaw in the direction
of the down Aileron, i.e. a roll to the right will cause the
aircraft to yaw to the left because the left Aileron deflects
downward and creates more drag. This, of course, is an
undesirable tendency that results in non-axial rolls and a
loss of heading.
The X9303 2.4 provides an Aileron Differential function
that allows adjustment of the Aileron that deflects
downward without affecting the Aileron that travels upward
and, therefore, can eliminate yaw tendencies in rolling
maneuvers. It can also affect only the Aileron that travels
upward—this is called negative differential and is useful if
an aircraft yaws in the same direction as the Aileron input.
Aileron differential is available in the FUNC.LIST only if
the FLAPERON Wing Type was selected in the Wing Type
function in the SYSTEM Menu or a Dual channel has been
assigned to ailerons in the Wing TYPE function.
The Aileron Differential function provides for 2 differential
settings that are switch or Flight Mode selectable – Pos0
and Pos1. The 2 settings can be combined in different
ways to provide one setting that is on all of the time, or
one setting that is on and one that is off (0 differential), or
2 different amounts of differential—maybe one for normal
flying and another for flat spins.
qualcuno riesce a spiegarmi con parole semplici a cosa serve e in quali casi è oppurtuno usarlo ?
Thanks
Daytona non è collegato   Rispondi citando
