Discussione: per chi ha RF G4
Vecchio 25 aprile 08, 18:58   #6 (permalink)  Top
urgno
L'avatar di urgno
Data registr.: 20-06-2007
Residenza: dintorni di Venezia
ecco la spiegazione:
INSTRUCTIONS
To download Add-On 1: Right-click here and save the file to disk. Choose a location that will be easy to find again.
To download Add-On 2: Right-click here and save the file to disk. Choose a location that will be easy to find again.
For each file downloaded above:
  1. Locate the file on your disk.
  2. Unzip the file. If you have Windows XP or Vista, you can just double-click it.
  3. Extract the .zip file's contents to "C:\Program Files\RealFlightG4\Data" (assuming you installed G4 in the default location).
cya
2x Prôtos Carbon Stretch FBL:MKS9660 / MKS9670 + BEASTX detti "i gemelli"
Acrobat Shark FBL +BEASTX detto "Emmenthal / Mucca"
urgno non è collegato   Rispondi citando
