Vecchio 24 maggio 04, 01:07   #1 (permalink)  Top
S_Ciambra
Guest
Messaggi: n/a
Nuove Li-Po 10,5 - 14 C...
FlightPower Extreme 10.5 - 14C LiPo
FPEX Carbon 11.1V, 3s2p 3200mAh.
Carbon Fibre reinforced ventillated super HD pack. 3200mAh 11.1V nominal. 158 x 44 x 24mm. Only 235g! 10.5-14C up to 44.8Amps continuous. 64Amp momentary peak. 9V minimum voltage on discharge 3.2Amp, 12.75V maximum charge values. Perfect perfomance pack for Robbe Eolo/Spirit Pro and models designed for 8-10 cell Sub-C packs. Note: Do not run below 3V per cell at high currents to avoid rapid overheating (use LiPo safe ESC or time your flights).
Le altre le trovate qui: FlightPower Extreme 10.5 - 14C LiPo
Saluti
  Rispondi citando
