Discussione: Hv 4.5 novak e cut off
Vecchio 21 febbraio 08, 10:03   #2 (permalink)  Top
REfuso
L'avatar di REfuso
Data registr.: 16-08-2007
Residenza: Bologna
Novak Electronics HV High-Voltage Brushless System (4.5)
This is the ultimate high-voltage system from Novak. The HV Brushless System 4.5 includes an HV High-Voltage Brushless ESC factory-wired to an HV4.5 Brushless Motor. The HV High Voltage ESC features 6-14 cell input, reverse disable, and a Marine throttle profile. Other ESC features include a heavy-duty BEC, Locked Rotor Detection Circuitry, Thermal Protection, and Direct Solder Wiring Tabs. Motor features include sensor technology, Novak’s Nickel-Plated Sintered Neodymium Rotor, aluminum ribbed end bells, and an oversized front bearing. The HV4.5 brushless motor has a factory-installed heat sink, and the ESC has a factory installed cooling fan. Nothing extra to buy or install. Ideal for the Traxxas® E-Maxx™ and other high-voltage applications. Also includes Novak's #5471 Smart Stop 4-Cell Li-Po Module for safe 4-Cell LiPo battery operation.
ciao, le ultime due righe dicono che include un cut off fino a 4 celle lipo.
Ma è l' e-maxx IperRegalo...della signora
ciao Al.
REfuso non è collegato   Rispondi citando
