Discussione: Mpx Evo 2.0 !!!!
Vecchio 16 febbraio 08, 10:53   #36 (permalink)  Top
Bad Attitude
L'avatar di Bad Attitude
Data registr.: 25-05-2005
Residenza: Montegrosso d'Asti
Good News!
Quotation MPX service (traduzione maccheronica dal tedesco):
after distribution of the EVO pro (Juni2008) it also a possibility of your EVO will give updates on the new software.
Also the enterprise of the PCM HF - module becomes possible.
If the transmitter is reequipped, also the high-grade steel antenna and/or the short antenna can be used.
A completely exact time and cost rail do not give it yet. To supplement it would be still that on use of the new PCM module also the high-grade steel or short antenna must be used.
In pratica tutte le vecchie EVO potranno essere aggiornate in PRO anche nell'hardware con il modulo PCM e le nuove antenne, se qualcuno ne sentisse la necessita'...
Piero
Bad Attitude non รจ collegato   Rispondi citando
