Vecchio 09 gennaio 08, 01:33   #10 (permalink)  Top
andreis
L'avatar di andreis
Data registr.: 23-12-2007
Residenza: Monza
Veeery nice job.
Many, many compliments.
Exactly as it is, so without brushless neither 3700mah LiPo, but with only a proper balancing lead, I whould see it to gorgeusly well fly like a PSS !!!!!
Ciao,
Antonio.
Originalmente inviato da W@CC0
Thank you for being a messenger boy Rob. Else I would never have thought on posting on an Italian forum.
As said previously by Rob,
Scale is 1/9th, span 1176mm and length 983mm
It will be powered with an electric brushless motor on 3 lipo's of 3700 mah turning an 8.5 x 7 or 8.5 x 5 aeronaut glass-e proppelor.
Construction is entirly in wood. THe wing is all balsa with a couple of ply reinforcements. The fuselage is made arround a ply frame that is planked with 2.5mm balsa. Tail and stabilizer are in Balsa.
It will be finished in the colors of a 369sq, 22gruppo plane.
Here are some pictures of the plane.
I will continue here(http://www.baronerosso.it/forum/show...148#post740148) because it is an electric plane.
Greetings
Tom
andreis non รจ collegato   Rispondi citando
