Vecchio 29 dicembre 07, 10:32   #3 (permalink)  Top
W@CC0
Data registr.: 29-12-2007
Residenza: Duffel; Belgium
--maybe I better continue here cause it is more on topic in the electric forum.--
Thank you for being a messenger boy Rob. Else I would never have thought on posting on an Italian forum.
As said previously by Rob,
Scale is 1/9th, span 1176mm and length 983mm
It will be powered with an electric brushless motor on 3 lipo's of 3700 mah turning an 8.5 x 7 or 8.5 x 5 aeronaut glass-e proppelor.
Construction is entirly in wood. THe wing is all balsa with a couple of ply reinforcements. The fuselage is made arround a ply frame that is planked with 2.5mm balsa. Tail and stabilizer are in Balsa. Aiming weight is under 1.5 kg
It will be finished in the colors of a 369sq, 22gruppo plane.
The sandcolor, gray and green meandering lines are airbrushed. The other things are hand painted.
Here are some pictures of the plane.
Greetings
Tom
Ultima modifica di W@CC0 : 29 dicembre 07 alle ore 10:39
W@CC0 non รจ collegato   Rispondi citando
