Discussione: Nuovo PCB MM2001
Vecchio 21 novembre 07, 20:49   #178 (permalink)  Top
xfifi
Data registr.: 17-11-2007
Originalmente inviato da saviothecnic
Mine excuses bad English
The mm2007 in comparison to the 2001 has:
Easiest best position of the compoentis to be climbed on
Easier to dissipate the integrated ones
Presence Integrated for regenerating signals parallel "Bufferz"
good for portable computers
Double integrated to improve the part of the temperature thread cut
Version both from 1A and also from 8A
always in a sideburn from 100x160 mm eurocad
The same PIC of the MM2001 uses therefore 100% compatible
with GMFC Pro
It supports emergency and the future use of the limit switch
that will go out in the new versions of GMFC
If you look for in this discussion you find one video of mine of testing
http://www.saviot.com/Download/CollaudoMM2007.wmv
Be se qualcunaltro in lista sa tradurre meglio si faccia avanti
Thank you very much for your reply.
The card is in final version or it is there yet of the planned changes ?
What kind of a stepping motor accept it? Still unipolar or bipolar now (it is becoming very difficult to find unipolar motors at low cost in France) ?
It would be very interesting that the evolution of the mm2001 can accept bipolar motors...
Grazie molte per il vostro risposta.
À la carte est essa it versione définitive o bien il yat'il bis prévues delle modifiche?
Quelle sorte di motore pas a pas accettati da essa? Sempre unipolaire o bipolaire maintenant (Il devient molto difficile di trouver dei motori unipolaires a faible coût it Francia)? Il serait intéressant molto che cette évolution di la mm2001 puisse accepter dei motori bipolaires ... <<<--- bad google translation
xfifi non è collegato   Rispondi citando
