Vecchio 31 ottobre 07, 22:42   #4 (permalink)  Top
icaro1
Data registr.: 23-10-2006
Per Quanto riguarda il motore avrei deciso per l'Hextronik HXT35-42A,
ora, vorrei un consiglio sul regolatore descritto di seguito o su una sua eventuale alternativa
Grazie di nuovo
hexTronik PRO 80A BESC w/ PC Programmability
Speed Controller Features
High rate (10 KHz) switching (PWM)
3 to 6 Li-poly cells with receiver.
Dynamic braking ensures prompt prop folding.
BEC (2.0A) provides power to receiver and servos.
Over temperature protection.
User programmable Features.
Low-voltage protection - Programmable
Cutoff can be programmed for motor stop or reduced power.
Brake Type.
Throttle Range.
Timing Advance.
Safe power onarming program.
Low torque “soft start?prevents damage to fragile gearboxes.
Auto shut down in 4sec after signal is lost or radio interference becomes severe.
Microprocessor controlled.
Programmable rotation.
A very high quality BESC.
Comes with a full 12 month warranty!
Specifics;
Max Load : 90A
Max Voltage : 6 cell 25v
BEC: 3A
As with all BESC using over 3cells, we urge you to dissable the BEC and use a seperate BEC or UBEC to power the Rx. This is the safest option.
icaro1 non è collegato   Rispondi citando
