Discussione: Piattine dal rowing?
Vecchio 26 luglio 07, 10:27   #10 (permalink)  Top
francesco+
L'avatar di francesco+
Data registr.: 04-02-2005
Unicarbon da rowing!
Leggete come il grande MD si fa il suo unicarbon!
Quote:
Originally Posted by arneansper
Can you please describe your procedure?
1) I first prepare a hard, flat, alcohol-proof working surface. I use 3 mil Mylar taped down to 1/4" plywood, but other surfaces should work OK.
2) I lay down the tows side by side with the appropriate spacing. With 12K tow, a 10mm spacing will give a material weight of 78 g/m^2 (2.3 oz/yd^2) -- other spacings will change the weight in inverse proportion. I made wood sticks with many wire pins with 4mm spacing, which I use to easily set the spacing at each end of the board, either 4mm, 8mm, 12mm, etc. It's essential that the tow not have any twists, otherwise it will not spead out. The tows are anchored at the ends.
3) I pour a generous amount of isopropyl alcohol ("rubbing alcohol" in the US) on the tows, and immediately cover them with another sheet of 3 Mil mylar.
4) I roll the Mylar/tow/Mylar sandwich with a wide hard-rubber roller to spread out the tows. If the tows don't spread out well, adding more alcohol usually helps. You want enough alcohol so that the fibers can "float" and move around.
5) I carefully peel off the top Mylar sheet to let the alcohol evaporate. The sizing chemical which is present in the tow will remain after the alcohol evaporates, and help hold the spread tows together in one sheet.
Even though some sizing is present, the sheet is still very flimsy and falls apart easily. To allow handling and cutting, I've had to apply a wax paper carrier with an extremely light 3M77 mist before peeling off the carbon from the bottom Mylar sheet. This still leaves some free fiber "fuzz", but it's good enough to work with.
I think one reason why some fibers are loose is that they don't make enough contact with other fibers as the alcohol evaporates. On the next batch I'll try pressing the carbon sheet with porous teflon and vacuum as the alcohol dries. Hopefully this will result in a much more solid sheet. Another possibility is adding a drop of epoxy to the alcohol, or maybe more sizing chemical (whatever that might be).
The carbon tow I'm using is Toho HMA-7C, which has a modulus of 52Msi, versus 30Msi for regular carbon. I got it real cheap on EBay I'm getting 10 gram DLG booms which are stiffer than the commercial 16 gram booms. I don't know how well they will hold up, though.
A settembre ci provo anch'io, col 24k però....
Vedremo cosa viene fuori.
Ciao malati
Francesco
francesco+ non è collegato   Rispondi citando
