SVIST
Model fitted with a powerful motor may fly any aerobatics. The battery is located in fuselage in an angle, so it falls out through the canopy during a hard landing and does not damage the RC equipment. The ailerons are controlled by independent mini servos. It makes aileron mixer possible to use also as brakes.
Detail pictureSpecial Features:- Fibreglass fuselage
- Foam core balsa sheeted two-piece wing with fibreglass reinforcement
- Pre-made servo trays
- 8 and 3 mm steel rod wing joiners
- Fibreglass canopy
- T stabiliser offers a better protection when landing on rough surfaces
- Pre-hinged, finished ailerons
- Transparent Oracover on wings and balsa tail parts
- Tight covering, with all seams hand-sealed
- Includes all necessary hardware
RC function:- Rudder, stabilizer, ailerons, motor
- ps nel catalogo c' è scritto.....
2760 mm
1260 mm
1200 g
RG 15 mod.
50,5 dm2
