Vecchio 14 maggio 07, 22:46   #3 (permalink)  Top
valpozzo
L'avatar di valpozzo
Data registr.: 14-08-2004
Io ho il modello vecchio, e si fa cosi' :
18A 30A ESC Instructions
TOWERPRO CO. LTD
BRUSHLESS MOTOR CONTROLLER
SETUP MENU (for new 18A and 30A)
Type
Current
Fe t
BEC
Timing mode
PWM
LIPO
NIHM
18-N
15-18A
12
5V/1A
2/7/15/30
8K
2 to 5
6/18
30-N
25-30A
15
5V/1A
2/7/15/30
8K
2 to 5
6/18
Limited to 3 cells in series for LIPO or 10 cells NIMh/NiCd with BEC enabled
Limited to 5 cells in series for LIPO or 18 cells NIMh/NiCd MAX with BEC disabled
To program the ESC you must connect the motor and ESC to the receiver.
1. Turn on the transmitter and place the throttle stick to full power position (full up position).
2. Energize the ESC by connecting the battery or power source to the speed controller. Five seconds after making the connection, you will hear a musical tone.
3. Move the throttle stick to half throttle. You will then hear each parameters musical tone twice, with a 3 second delay between each.
4. When you hear the tone to the parameter you want to change move the stick to full throttle. This will allow you to set the parameters to your specifications. The following symbols indicate the different main parameters with dashes representing number of tones
— Cell Type and Number
— — BRAKE
— — — TIMING MODE
— — — — Voltage Protection
After you have selected which main parameter to change, you will enter the sub-parameters. The procedure for setting them is the same as above. You will hear each musical sequence twice for each sub-parameter, and you will have three seconds between each sounding to move the throttle to full up position to save your choice. To confirm your choice you will hear a sharper tone indicating, this parameter has been saved. Below are the sub parameters for each of the above.
1.Cell Number and Type.
● — 2LIPO or NiMh/Nicd AUTO0.8V/CELL*
● — — 3LIPO 2.75V/CELL
● — — — 4LIPO2.75V/CELL
● — — — — 5LIPO2.75V/CELL
2. BRAKE SET
••— NO Brake
••— — SOFT Brake
••— — — MID Brake
••— — — HARD Brake
3. TIMING MODE SETTING
•••— 2º
•••— — 7 º
•••— — — 15º
•••— — — — 30º
4. Voltage Protection
••••— 2.8V/CELL
••••— — 2.9V/CELL
••••— — — 3.0V/CELL
Once more after you hear the parameter choice you want move the throttle stick to the full up position. You will hear a long sharp BEEP, this tone indicates the option to be saved and the system returns to the programming menu. When you have finished all programming pull the throttle stick to full down position, the speed control will make one final save of all settings and will arm the motor. You can now power up the motor!
Volare .... vola !
valpozzo non è collegato   Rispondi citando
