New Firmware & Windows, Android, iOS APP’s 3.4.201 release:
As usual new Firmware notifications will be automatic, and system will prompt user of the presence of new updates once powered unit is connected to a Windows PC or Android devices or iOS devices with Internet connection active.
For those with Brain2/iKon2 that do not frequently use the APP/Software (because the flight controller unit is fine as it was set up), let's take a look at what is coming with this update (for free) in addition to previous versions already released: - Software: 3.4.201, Firmware: 3.4.201 (68° official release), 12 February 2025:
• ESC Events: If errors are transmitted from the ESC telemetry while the flight control unit is still initializing, they are saved and recorded in the flight control unit's EVENTS immediately after initialization is completed
• The ‘Min V to go’ function now holds the motor in place even when YGE ESCs are used, which unlike all other ESCs, when programmed to work with Futaba brings the minimum value of throttle pulses to switch off the motor below 1000uS (to 950uS)
• JR X-Bus Protocol A: handle unforeseen situations where users incorrectly program transmitters with a throttle signal below -5% and/or above +105%
• The “Configure Bluetooth module” function to initialize and change PIN and NAME of Bluetooth modules now works with more model of Bluetooth modules (the total time the two LEDs both stays lit indicating the sending of the various initialization commands to BT module is now ~12 seconds)
• Added QOS for FrSky receivers that can set the serial output connected to CH3 to “SBUS out” mode (EG: TD-RXX)
• Now with Graupner ‘Basic telemetry’ (RPM for Nitro, Gasser, Turbine models) is also simulated with ‘HoTT Sensor Kind’ set to ESC (that is the default sensor kind) in case ELEC and GEN are already used by external sensors connected to the telemetry bus
• Improved in DIAGNOSTIC the resolution of vertical scale of VSAT parameter (renamed to “SAT Voltage”)
• Following the appearance of 12V servos on the market, event 161 (Servo Voltage greater than...) now occurs when the voltage exceeds 13V
• In COUNTERS added ‘One Way Bearing’ to the list of components whose time-of-use is to be calculated
• For receivers that can be programmed by the transmitters to use different protocols (EG: F.Port/F.Bus, Crossfire, etc.) the QOS values (Fades, Frame losses, Holds, Frame Rate, etc.) are reset to zero even when changing communication protocols without cycling the power supply
• When you give the command for elevator forward, in Wizard panel 5 and in ADVANCED section 2 the elevator slider moves to the right instead of the left, and in Realtime or recorded graphs, the elevator curve goes up instead of down
• Added inside “Brain2OpenTX-EdgeTX.zip” the new folder “_HOTT_MULTI”
• New version 29 of "Brain2_FwdPrg.lua" (inside the folder “_SRXL2_MULTI” in the “Brain2OpenTX-EdgeTX.zip”)
• Updated inside “Brain2OpenTX-EdgeTX.zip” the configuration example file “TX16S_Brain2.yml” for working also with Nitro / Gasser / Turbine models
• New version 29 of “Brain2OpenTX-EdgeTX.zip”
• New version 29 of “Brain2crossfire.zip”
• New version 29 of “Ethos_Integration.zip”
• New version 29 of “Brain2Jeti.zip”
• Updated Spektrum Integration
• Updated Graupner Integration
• New version of the embedded document “README_for_ESC_datas_log_and_telemetry.pdf”
• New version of the embedded document “README_for_OpenTX_EdgeTX_integration_for_BRAIN. pdf”
• New version of the embedded document “README_for_Spektrum_Integration.pdf”
• Added some instructions, changed some instructions, some tooltip, some labels in the app and also in the Integrations and also in the Events to be clearer
• Revised French instructions
• Improvements / optimization / compression / size reduction / code speedup Android / iOS app’s:
The code of the application was completely rewritten using a new and better development system with new libraries
All new features and improvements already listed for this "Software & "Firmware” release and in previous releases As usual, the release of Android and especially iOS apps publication still needs some time for testing and approval by Google & Apple
Enjoy!
