31 dicembre 22, 17:03
#1 (permalink)
Top |
| User
Data registr.: 17-06-2008 Residenza: Genova
| Outrage Velocity 90 lotto ricambi Outrage Velocity 90 lotto ricambi:
R90N271B-1 New Velocity 90 Base Frame 2mm, 1 new
R90N844B-SS Clutch Hub Assembly - Velocity 90, 3 new
R90N845B-SS Fan Shroud Assembly - Velocity 90 (without fan), 1 used
R90N845B-SS Fan Shroud Assembly - Velocity 90, 3 new
R90N849-SS Boom Mount Assembly - Velocity 90, 4 new
R90N849-SS Boom Mount Assembly - Velocity 90 (with 4 bearings and 2 white gears), 1 used
R90N852-SS Tail Bell Crank Assembly - Velocity 90, 1 new
R90N853-SS Front Boom Support Assembly - Velocity 90, 1 new
R90N855B Boom Tail Push Rod (without 3x R90N301 Tail Rod Push Rod Guide),1 used
R90N855B Boom Tail Push Rod, 1 used
R90N857-SS Stabilizer Mount Assembly - Velocity 90, 1 used
R90N858B-SS Boom Support CF Rod Assembly - Velocity 90, 1 used
R90N858B-SS Boom Support CF Rod Assembly - Velocity 90, 4 new
R90N869B-SS Tail Rod Guide Set with screws - Velocity 90, 2 new R90N872B-SS Tube Shaft Spline Set - Velocity 90, 3 new
SA00002A One Piece Engine Mount - Velocity 90, 2 new
oneway + main & tail gear, composed by:
R90N105-1 Main Gear 123T 1 Module (Injection) - Velocity 90, 1 used
R90N106-1 Main Drive Gear 111T 1 Module (Injection) - Velocity 90, 1 usedù
R90N846-SS Oneway hub assembly, 1 used
complete tail assembly, composed by:
R90N859-SS Tail Case Assembly - Velocity 90, 1 used
R90N860-SS Bell Crank Link Assembly - Velocity 90, 1 used
90N861-SS Tail Bell Crank Arm Assembly - Velocity 90, 1 used
R90N862-SS Tail Pitch Slider Assembly - Velocity 90, 1 used
SA00501A Tail Rotor Saft Assembly - Velocity 90 1 used
R550003-1 Carbon Fiber Fin Set (vertical only), 1 used
tail grip hub 1 used
plastic tail blade grips (bearings need replacement), 1 used
tail rotor shaft, composed by:
tail grip hub, 1 used
plastic tail blade grips (bearings need replacement) 1 used
Richiesta: 100€
Spedizione: Italia 10€, Europa 25€, Mondo 60€ --------------------------- Nome: Diego Cognome: Torazza Città: Genova |
