Discussione: Graupner Hott
Vecchio 25 novembre 21, 11:10   #2502 (permalink)  Top
msette
L'avatar di msette
Data registr.: 18-11-2003
Residenza: Verona
Dovrebbe essere la nominale, in quanto la casa dichiara un range tra 4.8 e 8.4 V
D625MW 32-Bit, High Speed, Metal Gear Servo
Product Description
The metal D-625MW is part of our D-Series servo line. All Hitec D-Series servos have been designed using our brand new, cutting edge, custom engineering. Combining industry leading high-resolution, state-of-the-art ultra-response technology with a 32-bit MCU and 12-bit ADC for unprecedented programmability and flexibility, these servos deliver significantly smoother movement. The speedy, powerful line operates on a wide 4.8 ~ 8.4 voltage range, allowing use with any common battery chemistry without the need for adapters or regulators. Featuring Hitec’s industry standard 25-tooth output spline with 3mm hex screw, each D-Series servo brings monster performance never known before in the market.
msette non è collegato   Rispondi citando
