Technical provisions UAS 6.1 A UAS that is to be used in operations under this PDRA should comply with the requirements of Part 16 of the Annex to Regulation (EU) 2019/9451, except that the UAS does not need to:
6.1.1 bear a Class C3 UAS or Class C5 UAS identification on itself;
6.1.2 be exclusively powered by electricity, if the UAS operator ensures that the environmental impact that is caused by the use of non-electric UAS is minimised;
6.1.3 include a notice that is published by EASA and provides the applicable limitations and obligations, as required by the UAS Regulation; and 6.1.4 include the manufacturer’s instructions for the UAS if it is privately built; however, information on its operation and maintenance, as well as on the training of the remote pilot, should be included in the OM.
Note 1: The UAS can comply with point (9) of Part 4 of the Annex to Regulation (EU) 2019/945 by using an add-on that complies with Part 6 of the Annex to said Regulation.
Note 2: If the UA does not have a physical serial number that is compliant with standard ANSI/CTA-2063-A ‘Small Unmanned Aerial Systems Serial Numbers’ and/or does not have an integrated system of direct remote identification, it can comply with point (9) of Part 4 of the Annex to Regulation (EU) 2019/945 by using an add-on that complies with Part 6 of the Annex to said Regulation.
Note 3: If the UAS is privately built, there may be no identification on the UA of its MTOM. In that case, the operator should ensure that the MTOM of the UA, in the configuration of the UA before take-off, does not exceed 25 kg.
__________________ Citazione:
Originalmente inviato da un mod Dire di essere in male fade equivale a minaccia... | |
