Vecchio 04 dicembre 20, 22:03   #6 (permalink)  Top
Hely84
Data registr.: 22-07-2018
Residenza: Italia
Exclamation
Originalmente inviato da starwars Visualizza messaggio
Oh..scusa ma.....tu non azzecchi una radio ehh..!..la Jeti non l'hai digerita. Ora esponi questo problema sul touch Futaba......magari una bella Taranis da 150 € risolve i tuoi problemi...
Attn: T32MZ Customers
Futaba Corporation of America Hobby Radio Control Department
Notice of free inspection of T32MZ transmitter
We have discovered that some inadequate parts were used in the manufacturing process of the T32MZ transmitter. A free inspection is being offered to those who have purchased or received a T32MZ transmitter within the serial number range noted below to determine if your radio was affected by these parts. If you have any questions, please contact us by following the instructions below. We will do our best to prevent this from happening in the future, and we thank you for your continued patronage to our products.
* Inspection details
There is a possibility that defective products have been mixed in with the internal wiring of the sticks/gimbals. We will inspect the gimbals and wiring harness of the corresponding lot for defective parts.
* Determination Method 1
The serial number is attached to the main battery compartment (red arrow in Fig. 1) which can be found by removing the battery cover. Numbers beginning with "B9" and "C001" to "C010" are subject to inspection. Product serial numbers that start with "C011" or later are not affected.
Corresponded serial numbers B9 *******
C001 *****
C002 *****
C003 ***** C004 ***** C005 ***** C006 ***** C007 ***** C008 ***** C009 ***** C010 ***** Il codice della mia inizia con la B9
Hely84 non è collegato   Rispondi citando
