questa e la procedura di binding che mi ha dato spektrum;
Yes, the DX6 black should work well with the mcpx V2.
It is very important that you follow this exact binding process:
Binding Procedure for Computer Radios
1. Disconnect the flight battery from the helicopter.
2. Power off the transmitter and move all switches to the 0 position.
3. Connect the flight battery to the helicopter. The 3-in-1 Control unit LED flashes after 5 seconds.
4. Push the bind switch/button while powering on the transmitter.
5. After 2–3 seconds, release the bind switch/button.
6. Move the rudder control stick to full right. Continue to hold the rudder control stick to full right until the blue LED on the 3-in-1 control unit is solid.
7. Release the rudder control stick.
8. Disconnect the flight battery and power the transmitter off
Step 6 is very important!!
praticemente, io non spostavo lo stik alettoni verso destra dopo aver mollato il pulsante di binding.....
