Vecchio 19 giugno 20, 18:45   #4 (permalink)  Top
AZlover
Data registr.: 17-06-2020
Residenza: New Hely Fly Club, Pantigliate (MI)
Originalmente inviato da Giulianoo Visualizza messaggio
Da un allegato che trovi sulla scheda "upload files"
YEP-Type (60A) brushless Electronic Speed Controller (ESC)
Technical data:
− 2 to 6s LiPo, with under voltage protection by power
reduction.
− 6 to 18 cells NiMH, with under voltage protection by power
reduction.
− the specified current is the maximum continuous full
power current with adequate cooling.
− under voltage detection (can be switched off).
− switching BEC: 5.5V, 3A continuous, 5A peak.
− Governor mode for Helicopters.
− Soft start.
− Active free-wheel, for efficiently part-load operation.
− Automatic or 6 step adjustable timing.
− adjustable F3A brake.
− 3 steps adjustable regular back EMF brake.
− Switching rate: 8 to 16 (?) kHz
− Speed limit: 240,000 RPM (2-Pole motors)
− Temperature and overload warning.
− Anti sparkling circuit: reduces connection sparkles.
− Programming with the ProgCard II or RC-Setup.
− Overall dimensions in mm: 62 x 25 x 8
− Weight in g without/with wires: 19 / 35
− Cable diameter Battery/Motor: 2.5mm² / 2.5mm²
su internet trovi le tabelle di conversione:
un 13 AWG equivale a 2,62 mmq
un 12 AWG equivale a 3,31 mmq
quindi direi un 12AWG per stare tranquilo.
Occhio a non allungare troppo i cavi.
Grazie mille, non avevo notato quella specifica! Come mai dici di non allungarli troppo? C'è qualche controindicazione?
AZlover non è collegato   Rispondi citando
