Discussione: Curiosità su DPR 100
Vecchio 05 maggio 07, 09:11   #9 (permalink)  Top
Electronicfly-rc
Rivenditore - Electronicfly-rc
L'avatar di Electronicfly-rc
Data registr.: 18-11-2006
Originalmente inviato da PAPERINO
Come bisogna collegarlo?
Ciao Paperino
Sono in ritardo ma quando si va adormire a notte fonda la mattina ( vedi pizza 2 baronerosso ieri sera con alcuni mitici frequentori del forum, a proposito ragazzi a conti fatti a mio avviso anche questa volta ci hanno bastonato con il prezzo , a mio avviso peggio della prima ) quindi tornando al DPR, si collega al pc con classico cavo USB peso del DPR 150 ca. gr.
Qui sotto alcuni dettagli in Inglese
DPR-II-100 and DPR-II-150 Key Features
-Very small: Approximately 1 inch X 1.2 inches
-Very Lightweight: Approximately 0.7 ounces (20 grams)
-Accepts wide range of Voltage inputs: Approximately 5.2 to 65 Volts
-Digitally records up to 72.8 hours of mission data
-Supports 12 bit data resolution
-Over sampling rate: Approximately 5,000 samples per second
-Supports live Real-Time Graph / Meter modes
-Offers dual ports for optional accessories *
-Firmware upgradeable online to support future enhancements
-Records and graphs in-use
Current load up to 100 Amps (up to 150 Amps with the DPR-II-150)
Battery Voltage from approximately 5.2 Volts to 65 Volts
Power output up to 6500 Watts (up to 9750 Watts with the DPR-II-150)
Amount of charge used (mAh)
Battery efficiency
Elapsed time of each mission
-Configurable
Data sampling rate (1-50 samples per second)
Data recording resolution
Recording trigger
Channels to record
Computer graphed displays with the powerful DPR-Graph software provided
-Very easy to set up and use!
* Optional dual temperature probe (TMP-2), temperature probe/LED alert indicator (TMP-LED),
RPM sensor (DPR-RPM), and 6 foot USB-A to mini-B cable (USB-6) may be purchased separately.
Saluti a tutti
Roberto
Electronicfly-rc
Electronicfly-rc non è collegato   Rispondi citando
