Lo chiedo perchè sul manuale della FrSky con le istruzioni per passare da FROS a OpenTx leggo questo:
"The FrSky X10S/X10 systems were provided with factory installed FrOS firmware. There
is no FrSky support planned for users that flash their X10S/X10 with OpenTX and have
problems with OpenTX or have problems flashing the system back to FrOS. Considering
the risk if there are problems you may not want to flash your system with OpenTX. If
you do change the OS system you do so at your own risk. "
