Discussione: Spritz E
Vecchio 05 novembre 19, 10:47   #290 (permalink)  Top
nicthepic
L'avatar di nicthepic
Data registr.: 26-11-2002
Residenza: Padova
Originalmente inviato da microcontrollorepic Visualizza messaggio
Fresco da FB
F5K power restrictions update rule:
When I started to design the new F5K contest I used my old Vortex 2.5 and searched for a motor to get a split second start and still keep all the thermal aspects of a DLG.
I selected a special Cobra E36 motor for this purpose: very light (<18 gram) and very strong. I made some calculations with ecalc and this showed me that the power with 2S is about 100 Watt (2S, 7.5x4 prop).
On 3S with prop 6x3 the power is about 150Watt. At that time I tried to limit the power to prevent very high launches. But after the introduction of the Nominal Launch Height I found a new mechanism to prevent very strong power drives as high launches brings you a lot of penalties.So after the test contest in Losser I decided to skip this aspect in the rule. I have uploaded the new version on the website. Result: maximum battery 3S and no limit in power anymore. I think this is more easy to control. You can find all info here: plane restrictions: Plane Restrictions
Plane Restrictions
Flavio
gli ho risposto che li teniamo d' occhio dall italia..
"W la gnocca "
nicthepic non รจ collegato   Rispondi citando
