Discussione: info tecniche
Vecchio 06 marzo 19, 13:50   #4 (permalink)  Top
noein1979
Data registr.: 27-01-2015
Residenza: Padova
si ma non ho capito come entra in funzione il cut-off
da manuale:
batterie:
For safety reasons, the low voltage cut-off settinf for Li-Po batteries is 3.2V/ cell
poi rimanda alla sezione setting
il settaggio predefinito e' Automatic (Medium)
Disabled
Automatic (Low)
Low voltage cutoff threshold is low and difficult lo activate. The protection function is active and can be applied lo batteries with low discharge capacity.
Automatic (Medium)
Medium threshold voltage cutoff. The protection function is activated and can be applied lo batteries with normai discharge capacity.
Automatic (High)
High threshold voltage cutoff. The protection function is easily activated and can be applied lo batteries with efficient discharge capacity.
Low Voltage Cut-Off
To properly maintain the lowest voltage of the Li-Po battery, set the cutoff voltage with the speed controlier.
The speed controlier constantly monitors the voltage of the battery. As soon as the voltage of the battery drops below the cutoff threshold, il reduces the power supply lo 50% lor 10 seconds and then shuts off power. The red LED emits a short flash to indicate the low voltage cutoff function is activated.
in generale mi sembrava di aver capito che non arrivare al cut-off o al 3.2/3.3V sia consigliato per allungare la vita della batteria
la cicalina e' uguale a quella dell'utente roby963
https://www.baronerosso.it/forum/eli...indicator.html
noein1979 non รจ collegato   Rispondi citando
