18 dicembre 18, 17:28
#6 (permalink)
Top |
| Sospeso
Data registr.: 06-08-2017 Residenza: Nord-Est
Originalmente inviato da raptor Prova a vedere questo se ti va bene LINK | Il manuale non si trova, ma in compenso c’è una gran confusione di sigle e di versioni: STD/OD, HS/FS, ecc. Citazione: http://www.south-coast-sailplanes.com/prismaray
Wing Span 3.72metres
Wing Area 85dmq
Wing profile HD-50mod 8.8%
Fuselage length 1.75m
Flying weight 6kg STD, 7.5kg HS
Controls A/F/R/E Centre of Gravity: 85mm from leading edge of wing root.
Standard servos of at least 13kg/cm torque are suggested for the ailerons & flaps.
Standard servos of at least 10kg/cm torque are suggested for the elevator & rudder http://www.south-coast-sailplanes.com
Prismaray OD (Overall Dynamics): “OD:- overall dynamics, stronger than the old STD. Gliders built of hollow moulded fibre glass with carbon spars and carbon/Kevlar reinforcements in the wings. The fuselages are strengthened with Kevlar and are 2.4Ghz friendly. Herex 1.2mm.”
Prismaray FS (Fast Slope): “FS:- Fast slope, stronger than the old HS The wings have one complete layer of carbon and a stronger spar. The fuselage has one more layer of Kevlar and are 2.4Ghz friendly. Herex is 1.2mm.”
Prismaray PD (Power Dynamics): “PD:- power dynamics. very strong models for top conditions.The wings have 2 complete layers of carbon and an even stronger spar. The fuselage has a heavier Kevlar layer and are 2.4 Ghz friendly. Herex is 1.4mm.”
Prismaray T (Texalio): “Texalio:- These are built of hollow moulded fibre glass impregnated with a silver paint to give a bright silver finish. The gliders have carbon/Kevlar reinforcements. A second colour is added to parts of the fuselage and wing tips and under the wings. These are very slightly heavier than the STD gliders”
Prismaray P (Performance): “Performance:- These gliders are made using carbon fibre cloth and so are very strong. These are also slightly heavier than the other 2 options.”
| Citazione: https://plane-expert.com/index.php?c..._attachment=82
• WING SPAN: 3,72 m
• LENGTH: 1,75 m
• WINGS AREA: 85 dmq (elevator excluded)
• IN-FLIGHT WEIGHT FROM: 6.0 Kg (Standard) – 7.5 Kg (Heavy Slope)
• COMMANDS: Aleirons, Flaps, Elevator, Rudder
• WINGS PROFILE: HD-50 mod.
• WINGS JOINTER: 16mm special steel rounded rod
Suggested setup:
• Center of Gravity: 110 mm from leading edge (taken from wing root) for maiden flight
• Wings incidence: + 0.5°/1°(1°is the suggest setup for maiden flight)
• Elevator movements: plastic flight +/- 15 mm; aerobatic +/- 20 mm (exp 40-50%, your choice)
• Aleirons movements: your choice, it’s not critical
• Rudder: as much as possible
| Citazione: http://www.xmodels.it/port-folio/prismaray/
APERTURA ALARE: 3,70 m
LUNGHEZZA: 1,75 m
SUPERFICIE ALARE: 88 dmq
• PESO A VUOTO: 3.8 Kg
PESO IN VOLO DA: 5.4 Kg STD 6.5 Kg HS
COMANDI: Alettoni, Flap, Elevatore, Deriva. Sgancio (opzionale)
PROFILO ALARE: MH 9% modificato
