Hi aerofast
Originalmente inviato da aerofast Second point: the pink foam that you used for bringing forms in your Mig-21, what kind of foam is??? |
the foarm is the poliuretane expance
if using that you can make all.
Originalmente inviato da aerofast Third point: is this foam no-reactive whith polyester resin??? |
No! because after used foil to alluminium for clothe masterpice.
[/QUOTE]
hi Migurel the you Mig-21 is very amazing.
i follow you always
